Acoustic Cavity meshing generates a fluid volume mesh used to calculate the acoustic modes (or standing waves) inside
the air spaces of a vehicle or similarly enclosed structural model.
Edit and test NVH templates used for creating lumped parameter (LP) models, multiple instances of one model transformed
to a new geometric location, or loadcases.
Package all project data (Assembly .xml files, Representation files, LP Templates, Loadcase files, Job files and CSV templates) for transfer to others or for
archival.
Coarsen Mesh
Simplify a mesh by combining many small elements into a smaller number of larger ones.
Acoustic Cavity Meshing
Acoustic Cavity meshing generates a fluid volume mesh used to calculate the acoustic modes (or standing waves) inside the air spaces of a vehicle or similarly enclosed structural model.
Frequency Response Process
Setup a frequency response analysis with a series of step-by-step process templates.
Macros
Access pre-defined macros packaged with the NVH solution and also user-defined macros.
Templates
Edit and test NVH templates used for creating lumped parameter (LP) models, multiple instances of one model transformed to a new geometric location, or loadcases.
Pack and Go
Package all project data (Assembly .xml files, Representation files, LP Templates, Loadcase files, Job files and CSV templates) for transfer to others or for archival.
Solver Deck Comparison
Allows for quick comparison of Main solver decks generated from the Analysis Manager or existing Main solver decks.
File Path Replace
Allows automatic mapping of modified and/or missing file paths and folders in the .xml file.
