Import and Export CSV Files
You can import and export comma separated value files (CSV) to and from TableView. There are two ways to access this feature:
  1. From the File menu, select Import > Table CSV or Export > Table CSV.
Or
  1. From the Standard toolbar, select the Import Table CSV icon, , or Export Table CSV icon, .
    TableView supports multiple lines of data in a single cell. To add a line break, press Alt + Enter. The Conditional Formatting and the Cell Data panels are disabled if you select a cell that contains multiple lines or if you press Alt + Enter.
    Note: See the Import Table CSV and Export Table CSV topics for more information.
    See the PowerPoint Publishing topic in the HyperWorks Desktop Overview help for more information on publishing your TableView session to a PowerPoint file.
