Standalone Applications Unit Draw
In addition to the applications listed above, there are several standalone applications that draw Altair Units. The following table is a summary of AUs drawn of those applications.
| Product | AUs | License Feature | Description |
| Embed OpenVision | No | No | Add-on for Embed. |
| Embed Viewer | No | No | Read-only version of Embed. |
| Embed Basic | 1 | EmbedBasic | Same as EMBED with a 100 block limit. |
| Embed eDrives | 4 | EmbedeDrives | A comprehensive set of motor control blocks covering AC Induction, BLDC, brushed, PMSM, and stepper motors for simulation, code generation, and HIL. |
| ESAComp | 6 | ESAComp | Composite design software. Units are stacked. |
| Embed Digital Power Designer | 10 | EmbedDigitalPower | Used for the design and development of digital power supplies and power conversion equipment. DPD is an Add-on for Embed. |
| Embed Simulation Edition | 10 | EmbedSimulation | Also known as EmbedSE, is a block diagram and state chart environment for modeling, simulation, analysis, and control system development. In addition to its simulation capabilities, it also supports real time data monitoring and control using National Instruments and other boards as well as OPC, CAN, UDP, Serial, and MQTT. |
| S-CONCRETE | 10 | StimberPro, StimberCSA, SfoundationPro, SfoundationACI, SfoundationCSA, SfoundationEURO, Scalc, StimberEnt, SfoundationEnt | Design and detail reinforced concrete beams, columns, and walls or continuous concrete beams to meet regional design code requirements and generate customizable design reports. Includes S-CONCRETE and S-LINE. |
| S-FRAME | 10 | SframePro, SsteelPro, Spad, Icd, Sview, Scalc, SframeEnt, SsteelEnt | Structural analysis with integrated steel and concrete design solutions enabling structural engineers to model and perform linear or advanced non-linear analysis. Design steel and concrete members to meet regional code requirements, generate design reports, and calculate advanced section properties for non-standard sections. Includes S-FRAME Analysis, S-STEEL, S-PAD, ICD, and S-CALC. |
| Structural Office | 10 | SconcreteStdFeature, Sline, SconcretePro, Sline, SconcreteEtabs | Hybrid timber structural analysis with integrated mass timber and foundation design solutions enabling structural engineers to simulate hybrid timber structures constructed from mass timber, steel, and concrete. Design mass timber members and concrete foundations to regional design code requirements, generate design reports, and calculate advanced section properties for non-standard sections. Includes S-TIMBER, S-FOUNDATION, and S-CALC. |
| Embed | 21 | EmbedCodeGen | Also called Embed Professional, is an extension of EMBED Simulation Edition for model-based firmware development supporting all microcontrollers, and with enhanced support for the following: Arduino®, ARM®-Linux® (Raspberry Pi™, AMD64, NVJetson/Nano), STMicroelectronics®, and Texas Instruments™. |
| EDEM BulkSim | 21 | EDEMBulkSimGUI | BulkSim GUI application. |
| 40 | EDEMBulkSimSolver | In CPU mode, using up to 12 cores it should be a constant draw of 40 AUs. | |
| 60 | EDEMBulkSimSolver | In GPU mode, it should pull the equivalent of 16 cores and draw 60 AUs. Stacking on the second plus. | |
| Flow Simulator | 50 | FSimGUI, FSimSolver |
Integrated flow, heat transfer, and combustion design software that enables mixed fidelity simulations to optimize machine and systems design. GUI levels. First solver instance levels, second plus stacks. |
| PollEx Logic/CAM | None | PollExEntity | Logic, CAM, BOM |
| PollEx UDE | Feature-based server | PollExUDEServer | |
| 4 | PollExUDEUser | Feature-based license server with a fixed annual per socket
up to 50 users. Additional checkout for each client access draws 4 AUs. |
| PollEx PCB Modeler | 10 | PollExBasic | PCB Modeler (PCB, Real PCB Assembly Viewer, Cross Probe (CP), UPE (Unified Part Editor)) |
| PollEx PCB Verification Post-Processing | 21 | PollExPostVerification | PCB Design for Manufacturing (DFM), Design for Assembly (DFA), Design for Electrical (DFE), Design for Electrical Plus (DFE+), Logic DFE – Result visualization |
| PollEx MFG | 30 | PollExMFG | PollEx Manufacturing options |
| PollEx PCB Solver | 30 | PollExSolver | PCB Solvers for signal integrity, power integrity, thermal analysis. |
| PollEx PCB Verification | 30 | PollExVerification | PCB Design for Manufacturing (DFM), Design for Assembly (DFA), Design for Electrical (DFE), Design for Electrical Plus (DFE+), Logic DFE. |
| Pulse | 30 | Pulse | Orchestrates meaningful models from the broad workflows required to simulate complex systems of systems to the focused workflows needed to enable fast, reliable, and repeatable modeling, analysis, and optimization. |
| SimSolid | 30 | SimSolid, SimSolidBasic |
A structural analysis software for fast design iteration. It eliminates geometry simplification and meshing, enabling the analysis of fully featured CAD assemblies without meshing. Levels at first instance, stacks at second plus. |
| 50 | SimSolidAdvanced | For fatigue, incremental non-linear, and batch mode. |
