OS-V: 0280 Axisymmetric Elements - Interference Fit Between Two Cylinders
The model examines the contact pressure between two cylinders in case of interference fit of 20 mm.
図 1. Model and Loading Description
Benchmark Model
2D axisymmetric elements (CQAXI) elements are used to model 2 cylinders.
- Material Properties
- Value
- Young's modulus
- 206 GPa
- Poisson's ratio
- 0
Nonlinear Static Analysis Results
OptiStruct | NAFEMS | Normalized Target Value | |
Contact Pressure | 2.35 | 2.27 | 1.035 |
図 2. Contact Pressure Between the Cylinders
Model Files
必要なモデルファイルのダウンロードについては、モデルファイルへのアクセスを参照してください。
The model file used in this example includes:
Interference_fit.fem
Reference
NAFEMS R0081 - Benchmark tests for finite element modeling of contact, gapping and sliding
