In order to keep an almost constant number of neighbors contributing at each particle, use
smoothing length varying in time and in space.
Consider
the smoothing length related to particle
(1)
and
if kernel correction
or
(2)
and
without kernel correction
At each time step, density is updated for each particle
, according to:
(3)
with
(4)
Where,
- Mass of a particle
- Density
- Velocity
Strain tensor is obtained by the same way when non pure hydrodynamic laws are used or in
the other words when law uses deviatoric terms of the strain tensor:
(5)
Next the constitutive law is integrated for each particle. Then Forces are computed
according to:
(6)
Where
and
are pressures at particles
and
, and
is a term for artificial viscosity. The expression is more
complex for non pure hydrodynamic laws.
注: The previous equation reduces to the following
one when there is no kernel correction:
(7)
since
Then, in order particles to keep almost a constant number of neighbors into their kernels (
is kept constant), search distances are updated according
to:
(8)
