STRING_READ
ModelingInputs a user-defined string.
Use
<Reference_String
id = "11401021"
label = "tpf full name"
usrsub_param_string = "USER(501,1001)"
usrsub_dll_name = "NULL"
usrsub_fnc_name = "STRING_READ"
/>Format
- Fortran Calling Syntax
SUBROUTINE STRING_READ (ID, PAR, NPAR, ERRFLG) - C/C++ Calling Syntax
void STDCALL STRING_READ (int *id, double *par, int *npar, int *errflg) - Python Calling Syntax
def STRING_READ(id, par, npar) return errflg - MATLAB Calling Syntax
function errflg = STRING_READ(id, par, npar)
Attributes
- ID
- [integer]
- PAR
- [double precision]
- NPAR
- [integer]
- ERRFLAG
- [integer]
def STRING_READ(id, par, npar):
iname = py_gtinam()
[string, istate] = py_gtstrg (int(par[1]))
errflg = py_put_string(id, string)
return errflgComments
- STRING_READ can only be defined for a string element. That is, Reference_String.
- The ID of the Reference_String defined with STRING_READ may be referenced the same way as a normal Reference_String element.
