/ANIM/SHELL/PHI
Engine Keyword Generates animation files containing angle between element skew and direction 1 orthotropy.
/ANIM/SHELL/PHI/Keyword4
Keyword4 Output location.
N
Layer number N
UPPER
Upper layer
LOWER
Lower layer (number of integration point is equal to one)
MEMB
Membrane
ALL
All the layers
  1. An N/A value will be output for any layer number that is requested, but does not exist in the model.
