New Keywords in 2022
2022
- /EBCS/NRF - New boundary condition option generalized for all ALE material laws
- /EOS/IDEAL-GAS-VT - Ideal gas equation of state (volume – temperature)
- /FAIL/ORTHBIQUAD - Orthotropic strain-based failure model
- /INIBRI/EREF - Option to initialize solid element with total or small strain formulation
- /MAT/LAW114 (SPR_SEATBELT) - 1D seatbelt spring material set
- /MAT/LAW117 - Mixed mode with linear softening
- /MAT/LAW200 (MDS) - Multiscale Designer material law
- /PROP/TYPE27 (SPR_BDAMP) - Damper spring property with one translational DOF
- /RETRACTOR/SPRING - 1D retractor for seatbelt
- /SLIPRING/SPRING - 1D slipring for seatbelt elements
- /TH/RETRACTOR - Time history output for the retractor element (/RETRACTOR)
- /TH/SLIPRING - Time history output for the slipring element (/SLIPRING)
- /TH/TRIA - Time History output for the /TRIA element
- /ALE/MAT, /EULER/MAT - Removed Flrd flag
- /FAIL/ALTER - Added new failure model based on Phd Thesis of Christopher Brokmann
- /FAIL/GURSON - Added parameter for automatic non-local length computation
- /INIBRI/STRA_F and /INIBRI/STRA_FGLO - Added new fields nptr, npts, nptt, and nlay
- /INIBRI/STRS_F and /INIBRI/STRS_FGLO - Added new fields nptr, npts, nptt, nlay and grbric_ID
- /INTER/SUB - Added feature to scale the damping value function of time with user input function
- /LOAD/PBLAST - Added feature to correlate positive impulse in addition to positive peak pressure
- /MAT/LAW34 (BOLTZMAN) - Material compatible with shell (/SHELL and /SH3N) elements, beam elements (/BEAM) and truss elements (/TRUSS)
- /MAT/LAW35 (FOAM_VISC) - Added new strain rate filtering
- /MAT/LAW43 (HILL_TAB) - Added new strain-rate filtering parameters, Fcut and Fsmooth
- /MAT/LAW57 (BARLAT3) - Added strain rate filtering
- /MAT/LAW78 - Added new parameters and .
- /MAT/LAW80 - Enhanced with new developments in hot stamping/press hardening to better predict the martensite volume fraction
- /MAT/LAW83 - Added option Icomp=1
- /MAT/LAW87 (BARLAT2000) - Added new hardening formulation based on Chaboche & Rousselier formulation and Hansel formulation
- /MONVOL/FVMBAG1 and /MONVOL/FVMBAG2 - Added new option Iswitch=2
- /PROP/TYPE9 (SH_ORTH), and /PROP/TYPE10 (SH_COMP) - Added new skew_ID and IP flags
- /PROP/TYPE6 (SOL_ORTH), /PROP/TYPE11 (SH_SANDW), /PROP/TYPE16 (SH_FABR), /PROP/TYPE51, and /STACK - Added new IP flag
- /SENSOR/ENERGY - Added new feature to activate the sensor with the total energy and new feature to activate the sensor when the internal and kinetic energy is constant for a defined time value.
- /TH/BRIC - Added new outputs for 3D solid element to display material velocity, speed of sound & Mach number in the time history file
- /TH/QUAD - Aded new outputs for 2D solid element to display material velocity, speed of sound & Mach number in the time history file
- /VISC/PRONY - Added new viscous model defined by time relaxation curve or Dynamic Mechanical Analysis (DMA). Radioss automatically fits the viscous parameters (prony series values).
- /ALE/MUSCL/OFF - Disable MUSCL scheme
- /ANIM/VECT/PCONT2 and /ANIM/NODA/PCONT2 - Added new output option to display contact pressure for tied contact
- /H3D/RBE2/SINGLE_PART - Display all RBE2 in a single part
- /H3D/RBE3/SINGLE_PART - Display all RBE3 in a single part
- /H3D/RBODY/SINGLE_PART - Display all rigid bodies in a single part
- /H3D/SHELL/MDS/* and /H3D/SOLID/MDS/* - Added new .h3d output for the MDS material law
- /H3D/SHELL/PEXT and /H3D/SOLID/PEXT - Added new output to display the pressure imposed by the options /PLOAD, /LOAD/PFLUID, /LOAD/PBLAST and /BEM/DAA
- /H3D/RBE2/SINGLE_PART - Added new option in the native H3D output to display only 1 component for all RBE2s
- /H3D/RBE3/SINGLE_PART - Added new option in the native H3D output to display only 1 component for all RBE3s
- /H3D/RBODY/SINGLE_PART - Added new option in the native H3D output to display only 1 component for all RBODYs
- /INIV/AXIS/Keyword3/2 - Initialize rotational velocity about an axis and translational velocity on a node set
- /INIV/ROT/Keyword3/2 - Initialize rotational velocity in the specified direction X, Y or Z on a node set
- /INIV/TRA/Keyword3/2 - Initialize translational velocity in the specified direction X, Y or Z on a node set
- /STATE/BRICK/EREF - Added new option to output reference state for solid element with total or small strain formulation
- /IMPL/QSTAT/MRIGM - Added new option to set 3 reference nodes for the rigid body mode computation.
- /INIV/AXIS/Keyword3/2, /INIV/ROT/Keyword3/2, /INIV/TRA/Keyword3/2 - Added new option to define initial velocity on a node set defined in the model.
- /STOP/LSENSOR - Added new flag to output state file with LS-DYNA format (.dynain).
- *CONTACT_NODES_TO_SURFACE - Define nodes to surface contact interface.
- *DEFINE_TRANSFORMATION - Defines a node and entities transformation(s) used in *INCLUDE_TRANSFORM
- *LOAD_GRAVITY_PART - Defines gravity load applied to a part or to a set of parts
- *LOAD_SHELL - Defines pressure load on a single shell element or on a set of shell elements
- *SET_BEAM_INTERSECT, *SET_DISCRETE_INTERSECT, *SET_NODE_INTERSECT, *SET_SEGMENT_INTERSECT, *SET_SHELL_INTERSECT, *SET_SOLID_INTERSECT - Defines a set from the intersection of set lists of elements.
- *CONSTRAINED_NODAL_RIGID_BODY - Added available to set NSID=0
- *CONTACT_AUTOMATIC_GENERAL, *CONTACT_AUTOMATIC_NODES_TO_SURFACE, *CONTACT_AUTOMATIC_SINGLE_SURFACE, *CONTACT_AUTOMATIC_SURFACE_TO_SURFACE, and *CONTACT_ERODING_SINGLE_SURFACE - Added parameter SOFT of the additional card A is read
- *DATABASE_BINARY_INTFOR - Option FILE is accounted for
- *INITIAL_VELOCITY - Exempted nodes are accounted for
- *SET_BEAM, *SET_DISCRETE, *SET_NODE, *SET_PART, *SET_SEGMENT, *SET_SHELL, and *SET_SOLID - Added option COLLECT.
- *SET_SEGMENT - Added GENERAL
