/TH/TRIA
Block Format Keyword Describes the time history for a tria.
| /TH/TRIA/thgroup_ID | |||||||||
| thgroup_name | |||||||||
| var_ID1 | var_ID2 | var_ID3 | var_ID4 | var_ID5 | var_ID6 | var_ID7 | var_ID8 | var_ID9 | var_ID10 |
| elem_ID | elem_name | ||||||||
| thgroup_ID | TH
group identifier (Integer, maximum 10 digits) |
| thgroup_name | TH
group name (Character, maximum 100 characters) |
| var_ID1, ...n | Variables saved for
TH (see table below) (Character, maximum 8 characters) |
| elem_ID | Element
identifier (Integer) |
| elem_name | Name of the element to
appear in the time history (Integer, maximum 80 characters) |
TH Output Keyword & Variables
| Keyword | Object Saved | Variables |
| TRIA | 2D tria | VX, VY, VZ, SSP, MACH |
Output for Tria
| Output for Tria | Available for Material Law |
| VX, VY, VZ | All materials that are compatible with TRIA elements |
| SSP | All materials that are compatible with TRIA elements |
| MACH | All materials that are compatible with TRIA elements |
- Available names are listed in the
two tables above.
In the first table, TH-variables are listed. If a TH-variable is requested, this variable is written.
In the second table, other variable groups are listed. If a variable group is requested, all the associated TH-variables are written at once.
