/TH/FRAME
Block Format Keyword Describes the time history for frames.
| /TH/FRAME/thgroup_ID | |||||||||
| thgroup_name | |||||||||
| var_ID1 | var_ID2 | var_ID3 | var_ID4 | var_ID5 | var_ID6 | var_ID7 | var_ID8 | var_ID9 | var_ID10 |
| Obj_ID1 | Obj_ID2 | Obj_ID3 | Obj_ID4 | Obj_ID5 | Obj_ID6 | Obj_ID7 | Obj_ID8 | Obj_ID9 | Obj_ID10 |
| thgroup_ID | TH
group identifier (Integer, maximum 10 digits) |
| thgroup_name | TH
group name (Character, maximum 100 characters) |
| var_ID1, ...n | Variables saved for
TH (see table below) (Character, maximum 8 characters) |
| Obj_ID1, ...n | Identifiers of the objects
to be saved (Integer) |
TH Output Keyword & Variables
| Keyword | Object Saved | Variables |
| FRAME | Frame | OX, OY, OZ, R11, R12, R13, R21, R22, R23,
R31, R32, R33 VX, VY, VZ, VRX, VRY, VRZ, AX, AY, AZ, ARX, ARY, ARZ |
Table of Available Variables - Part 2
| Keyword | Variable Group | Saved TH Variables |
| FRAME | DEF | OX, OY, OZ, R11, R12, R13, R21, R22, R23, R31, R32, R33, VX, VY, VZ, VRX, VRY, VRZ |
O+R V+VR A+AR |
OX, OY, OZ, R11, R12, R13, R21, R22, R23, R31, R32, R33 VX, VY, VZ, VRX, VRY, VRZ AX, AY, AZ, ARX, ARY, ARZ |
Output for Frame
- OX, OY, and OZ: coordinates of the frame origin
- R11, R12, R13, R21, R22, R23, R31, R32, and R33: components of the orientation matrix
- VX, VY, and VZ: components of the translational velocity
- VRX, VRY, and VRZ: components of the instantaneous rotational velocity
- AX, AY, and AZ: components of the translational acceleration
- ARX, ARY, and ARZ: components of the instantaneous rotational acceleration
- Available names are listed in the two
tables above.
In the first table, TH-variables are listed. If a TH-variable is requested, this variable is written.
In the second table, other variable groups are listed. If a variable group is requested, all the associated TH-variables are written at once.
