/TH/SPHCEL
Block Format Keyword Describes the SPH cell output to time history.
/TH/SPHCEL/th_group_ID | |||||||||
th_group_title | |||||||||
var_ID1 | var_ID2 | var_ID3 | var_ID4 | var_ID5 | var_ID6 | var_ID7 | var_ID8 | var_ID9 | var_ID10 |
sphcel_ID | sphcel_name |
th_group_ID | Time history group
th_group_title | Time history group
var_ID1, ..n | Variables saved for
TH (see table below) (Character, maximum 8 characters) |
sphcel_ID | Particle
identifier (Integer) |
sphcel_name | Name of the particle to
appear in time history (Character, maximum 100 characters) (Integer) |
- Variable names must be left justified.
- Available names are listed in the
two tables below.
In the first table, TH-variables are listed. If a TH-variable is requested, this variable is written.
In the second table, other variables are listed. If a variable group is requested, all the associated TH-variables are written at once.
- If variable name is
ALL, all TH-variables are saved for this
object.
- Variables
- OFF, SX, SY, SZ, SXY, SYZ, SXZ, IE, DENS, WFVIS, VOL, PLAS, TEMP, PLSR, VPLA and DIAMETER
Variable Saved TH-variables DEF OFF, SX, SY, SZ, SXY, SYZ, SXZ, IE, DENS, PLAS, TEMP - Same variables for the option /TH/BRIC are available; except for variable QVIS, which is not available and variables WFVIS (work of artificial viscous forces) and DIAMETER (diameter of the particle) were added.
- The following variables are
available for all material laws:
- Variable
- Description
- OFF
- Element flag
- SX, SY, SZ, SXY, SYZ, SXZ
- Stresses in global system
- IE
- Specific internal energy per initial volume
- DENS
- Density
- VOL
- Particle initial volume
- WFVIS
- Work of artificial viscous forces
- DIAMETER
- Particle diameter (smoothing length)
- The following variables are only
available for the material laws listed:
Variable Description Law Numbers TEMP Temperature 4, 6, 11, 33, 38 PLAS Equivalent plastic strain 2, 3, 4, 22, 23, 33, 38 PLSR Plastic strain rate 4, 33, 38 VPLA Equivalent volumetric plastic strain 10
