/TH/FXBODY
Block Format Keyword Outputs the time history for flexible bodies.
/TH/FXBODY/thgroup_ID
thgroup_name
var_ID1 var_ID2 var_ID3 var_ID4 var_ID5 var_ID6 var_ID7 var_ID8 var_ID9 var_ID10
fxbd_ID1 fxbd_ID2 fxbd_ID3 fxbd_ID4 fxbd_ID5 fxbd_ID6 fxbd_ID7 fxbd_ID8 fxbd_ID9 fxbd_ID10
fxbd_IDn
thgroup_ID TH group identifier.
(Integer, maximum 10 digits)
thgroup_name TH group name.
var_ID1, ...n Variables saved for TH (see table below).
(Character, maximum 8 characters)
fxbd_ID Identifier of the flexible body to which the mode belongs.
(Integer)
TH Output Keyword & Variables
Keyword Object Saved Variables
FXBODY Flexible body IE, KE, EFW, DE
Table of Available Variables - Part 2
Keyword Variable Group Saved TH Variables
FXBODY DEF IE, KE, EFW
Output for Flexible Body
IE
Internal energy
KE
Kinetic energy
EFW
Work of applied forces
DE
Damping energy
  1. Available names are listed in the two tables above.
    In the first table, TH-variables are listed. If a TH-variable is requested, this variable is written.
    In the second table, other variable groups are listed. If a variable group is requested, all the associated TH-variables are written at once.
