Block Format Keyword In this group, keywords are used to set default value, global parameter, analysis type, input/output print,
damping and ALE and CFD treatment for the whole model. For default value, it is still possible to overwrite in each
specific keywords.
Block Format Keyword In this group, keywords are used to combine material and property information (/PART), assemble model (/SUBSET) or define a separate model (//SUBMODEL).
Block Format Keyword Interfaces solve the contact and impact conditions between two parts of a model. Several interface types are available
in Radioss and use different contact treatments.
Block Format Keyword Radioss supports several different kinematic constraints, which are mainly used to impose acceleration, velocity, displacement
or temperature in structure or constraint the moving of structure. They are mutually exclusive for each degree-of-freedom
(DOF). Two kinematic conditions applied to the same node may be incompatible.
Block Format Keyword In Radioss the following load cases are available. Stress/strain as initial state could be considered by modeling, as well as
pressure, gravity, and thermal load.
Block Format Keyword Adaptive Meshing is used in metal forming to divide the element to better describe the geometry. /ADMESH/GLOBAL and /ADMESH/SET are not available for SPMD computation.
Block Format Keyword Defines a sub-interface. A sub-interface is a portion of an existing interface and is defined in order to output the forces
applied by nodes of a specified node group on the segments of a specified surface (refer to Time Histories output for interfaces).
/GAUGE/SPH Block Format Keyword Defines SPH gauges.
/INTER/SUB Block Format Keyword Defines a sub-interface. A sub-interface is a portion of an existing interface and is defined in order to output the forces applied by nodes of a specified node group on the segments of a specified surface (refer to Time Histories output for interfaces).
/SECT Block Format Keyword Sections are used to output the force and moment of a cross section defined by a group of nodes and groups of elements.
/SECT/CIRCLE Block Format Keyword A circle section is used to output the force and moment of a cross section defined by a circular disc.
/SECT/PARAL Block Format Keyword A parallelogram section is used to output the force and moment of a cross section defined by a parallelogram.
