/INTER/SUB
Block Format Keyword Defines a sub-interface. A sub-interface is a portion of an existing interface and is defined in order to output the forces applied by nodes of a specified node group on the segments of a specified surface (refer to Time Histories output for interfaces).
/INTER/SUB/sub_inter_ID | |||||||||
sub_inter_title | |||||||||
inter_ID | Main_ID1 | Second_ID | Main_ID2 |
sub_inter_ID | Sub interface identifier. (Integer, maximum 10 digits) |
sub_inter_title | Sub interface title. (Character, maximum 100 characters) |
inter_ID | Interface identifier for the main
interface which contains the sub interface. (Integer) |
Main_ID1 | Main identifier.
Second_ID | Secondary identifier.
Main_ID2 | Second main surface identifier.
- Only interface TYPE7, TYPE10, TYPE11, TYPE19, TYPE24 and TYPE25 are available for defining sub-interfaces.
- A hierarchy of sub-interfaces is not permitted.
- An interface and a sub-interface cannot have the same identifier.
- For sub-interfaces of TYPE7 TYPE10, TYPE11, TYPE19 and TYPE24:
All segments of the specified main surface or main line in the sub interface should belong to the main surface or main line of the interface.
All segments of the specified secondary surface or secondary line in the sub interface should belong to the secondary surface or secondary line of the interface.
- For sub-interfaces of a TYPE19 interface,
if Second_ID = 0, then the sub-interface is symmetric and
Main_ID is also used as secondary surface.
Figure 1. - For sub-interfaces of a TYPE25
interface:
If Second_ID ≠ 0, the forces applied by the secondary node group onto both main surfaces are considered.
If Main_ID2 ≠ 0, the forces applied by Main_ID1 onto Main_ID2 and vice versa are calculated.
