/TH/PART
Block Format Keyword Describes the time history for parts.
/TH/PART/thgroup_ID | |||||||||
thgroup_name | |||||||||
var_ID1 | var_ID2 | var_ID3 | var_ID4 | var_ID5 | var_ID6 | var_ID7 | var_ID8 | var_ID9 | var_ID10 |
Obj_ID1 | Obj_ID2 | Obj_ID3 | Obj_ID4 | Obj_ID5 | Obj_ID6 | Obj_ID7 | Obj_ID8 | Obj_ID9 | Obj_ID10 |
thgroup_ID | TH
group identifier (Integer, maximum 10 digits) |
thgroup_name | TH
group name (Character, maximum 100 characters) |
var_ID1, ...n | Variables saved for TH
(see table below) (Character, maximum 8 characters) |
Obj_ID1, ...n | Identifiers of the objects
to be saved (Integer) |
TH Output Keyword & Variables
Keyword | Object Saved | Variables |
PART | Parts | IE, KE, XMOM, YMOM, ZMOM, MASS,
HE TURBKE, XCG, YCG, ZCG, XXMOM, YYMOM, ZZMOM IXX, IYY, IZZ, IXY, IYZ, IZX, RIE, KERB, RKERB, RKE |
Table of Available Variables - Part 2
Keyword | Variable Group | Saved TH Variables |
PART | DEF | IE, KE, XMOM, YMOM, ZMOM, MASS, HE |
Output for Part in the Global Skew System
- IE: internal energy
- KE: kinetic energy
- XMOM: translational X momentum in the global reference frame
- YMOM: translational Y momentum in the global reference frame
- ZMOM: translational Z momentum in the global reference frame
- MASS: mass of the part excluding mass added due to mass scaling /DT/NODA/CST
- HE: hourglass energy and numerical damping. See Comment 6.
- TURBKE: turbulence kinetic energy (only for fluid applications)
- XCG: center of gravity coordinates
- YCG: center of gravity coordinates
- ZCG: center of gravity coordinates
- XXMOM: rotational X momentum in the global reference frame
- YYMOM: rotational Y momentum in the global reference frame
- ZZMOM: rotational Z momentum in the global reference frame
- IXX: inertia matrix
- IYY: inertia matrix
- IZZ: inertia matrix
- IXY: inertia matrix
- IYZ: inertia matrix
- IZX: inertia matrix
- RIE: shear internal energy
- KERB: transitional rigid body kinetic energy. See Comment 7
- RKERB: rotational rigid body kinetic energy. See Comment 7
- RKE: rotational kinetic energy
- A part (resp. a subset) can not be in several time history groups. In this case, the only variables output in time history are the variables declared in the last option which refers to the part (resp. subset).
- Available names are listed in the two
tables above.
In the first table, TH-variables are listed. If a TH-variable is requested, this variable is written.
In the second table, other variable groups are listed. If a variable group is requested, all the associated TH-variables are written at once.
- In 2D axisymmetrical computation, energies are given per radian.
- If requested part is a Thpart, refer to Time Histories (Part definitions).
- Output for subset or part (for /TH/SH3N or /TH/SHEL
only):
HE: global hourglass energy with visco-energy added for numerical stabilization if QBAT and QEPH shell formulations (Ishell =12, 24) are used (refer to /PROP/TYPE1 (SHELL)).
- HE output is perturbation hourglass energy for shell elements, Ishell = 1 – 4, and Ish3n = 1, 2 and is defined in the element properties using hm, hf, and hr. For Ishell = 12, 24 and Ish3n = 30, 31, the output is numerical damping and is defined in the element properties using dm and dn. Note that numerical damping is not included in the global hourglass energy calculation. For solid elements Isolid = 1, 2, the output is perturbation hourglass energy and is defined using solid element property, h.
- Any motion can always be represent rigid body motion (translation or rotation) and deformation modes. KERB and RKERB are the rigid part of motion from deformable or undeformable modes.
