*SET_PART
LS-DYNA Input Interface KeywordDefines a set of parts based on a list or generates a list by specifying a range of part IDs.
(1) (2) (3) (4) (5) (6) (7) (8)
*SET_PART_{OPTION1}_{OPTION2}
set_ID
If OPTION1 = LIST, repeat the following line, as needed.
PID1 PID2 PID3 PID4 PID5 PID6 PID7 PID8
If OPTION1 = LIST_GENERATE, repeat the following line, as needed.
PIDB1 PIDE1 PIDB2 PIDE2 PIDB3 PIDE3 PIDB4 PIDE4
If OPTION1 = LIST_GENERATE_INCREMENT, repeat the following line, as needed.
PIDB PIDE INCR
If OPTION1 = COLUMN, repeat the following lines for each TYPE used.
PID
Definition
OPTION1
LIST (Default)
The parts in the set are listed 8 per line until the next keyword.
LIST_GENERATE
The parts in the set include all the parts between PIDB1PIDE1, PIDB2PIDE2, PIDB3PIDE3, etc.
The parts in the set include all the parts between PIDBPIDE with the increment value INCR.
COLUMN
The parts in the set are listed 1 per line until the next keyword.
OPTION2
<BLANK> Default
Each set is treated separately. Sets cannot share the same ID.
COLLECT
All *SET_PART with this option and the same ID are combined together into a single set.
set_ID Part set identifier.
(Integer)
PID1 - PID8 Part IDs, 8 per line.
(Integer)
PIDB1 - PIDB4 First part ID of the range, up to 4 per line.
(Integer)
PIDE1 - PIDE4 Last part ID of the range, up to 4 per line.
(Integer)
PIDB First part ID of the range.
(Integer)
PIDE Last part ID of the range.
(Integer)
INCR Increment value for the list generation from PIDB to PIDE.
Default = 1 (Integer)
PID Part ID, 1 per line.
(Integer)
  1. This keyword maps to /SET.
  2. The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
