*MAT_181 (SIMPLIFIED_RUBBER/FOAM)
LS-DYNA Input Interface KeywordDefines a rubber and foam material with uniaxial tensile/compression test results as input curve. This material can be used with solid elements only.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *MAT_181 or *MAT_SIMPLIFIED_RUBBER/FOAM | |||||||
| mat_ID | K | G | |||||
| Length | Wide | Thick | Table_ID | Tension | |||
| Fct_unl | Hys | Shape |
Definition
| mat_ID | Material identifier. (Integer) |
| Poisson's ratio. (Real) |
| K | Bulk modulus. (Real) |
| G | Shear modulus. (Real) |
| Length | Specimen gauge length. (Real) |
| Wide | Specimen gauge width. (Real) |
| Thick | Specimen gauge thickness. (Real) |
| Table_ID | Curve or table ID defining the force versus gauge length and
for the different strain rate value defined in the
table. (Integer) |
| Tension | Unloading rate effects option flag.
(Integer) |
| Fct_unl | Unloading curve ID. (Integer) |
| Hys | Hysteresis unloading factor. Ignore if, unloading function is
used. 0.0 ≤ Hys ≤ 1.0 Default = 0 (Real) |
| Shape | Shape factor. Ignored if, unloading function is
used. Default = 1.0 (Real) |
- This keyword maps to /MAT/LAW70 (FOAM_TAB) for foam, and /MAT/LAW88 for the hyperelastic materials.
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
