*SET_SHELL_ADD
LS-DYNA Input Interface KeywordDefines a set of shell elements based on a list of set of shell elements.
(1) (2) (3) (4) (5) (6) (7) (8)
*SET_SHELL_ADD
set_ID
Repeat the following line as needed.
Set_ID1 Set_ID2 Set_ID3 Set_ID4 Set_ID5 Set_ID6 Set_ID7 Set_ID8
set_ID Set identifier.
(Integer)
Set_IDi Shell set ID to add in the set.
(Integer)
  1. This keyword maps to /SET/GENERAL.
  2. The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
