*NODE_TRANSFORM
LS-DYNA Input Interface KeywordDefines a node coordinate transformation applied on a set of nodes.
(1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
*NODE_TRANSFORM | |||||||
TRA_ID | Set_ID |
TRA_ID | Transformation ID
(*DEFINE_TRANSFORMATION). (Integer) |
Set_ID | Node set ID. (Integer) |
- This keyword maps to /TRANSFORM cards.
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
