*MAT_ADD_EROSION
LS-DYNA Input Interface KeywordThis model expresses different failure models which can be added on various material models.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *MAT_ADD_EROSION | |||||||
| mat_ID | EXCL | MNEPS | EFFEPS | P_thinfail | |||
| MXEPS | |||||||
| IDAM | fct_IDel |
| IDAM | DMGTYP | LCSDG | ECRIT | DCRIT | FADEXP | fct_IDel | |
| El_ref |
| LCFLD |
Definition
| mat_ID | Material identifier. (Integer) |
| EXCL | Exclusion Number. All parameters with EXCL
value are ignored from the failure model. (Real) |
| MNEPS | Second principal strain for failure. (Real) |
| EFFEPS | Maximum effective strain failure.
(Integer) |
| P_thinfail | Number of thickness integration points that must fail before
the element is deleted.
(Real) |
| MXEPS | First principal strain for failure. (Real) |
| IDAM | Failure model option.
(Integer) |
| DMGTYP | GISSMO damage type.
(Integer) |
| LCSDG | Function or Table identifier defining equivalent
plastic. Strain to failure versus triaxiality and Lode parameter value. (Integer) |
| ECRIT | Instability strain table identifier.
(Real) |
| DCRIT | Critical accumulated damage value. (Real) |
| FADEXP | Fading exponent.
(Real) |
| fct_IDel | Function Identifier for the element size dependent
regularization. Factors at failure. (Integer) |
| El_ref | Reference element size. Default = 1.0 (Real) |
| LCFLD | Function identifier (FLD diagram). (Integer) |
- This keyword maps to /FAIL/TENSSTRAIN, /FAIL/TAB1, /FAIL/JOHNSON, and/or /FAIL/FLD.
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
