*CONTACT_AUTOMATIC_SINGLE_SURFACE
LS-DYNA Input Interface KeywordDefine automatic single contact interface between elements.
(1) (2) (3) (4) (5) (6) (7) (8)
*CONTACT_AUTOMATIC_SINGLE_SURFACE_{OPTION3}
If OPTION3 = ID, insert the following line.
inter_ID Title
SSID   SSTYP
FS FD DC       Tstart Tstop
SFS   SST   SFTS   FSF
Optional Card A
SOFT
Definition
OPTION3
ID
Include a contact identifier and title.
inter_ID Contact interface identifier.
(Integer)
Title Contact interface title.
(Character, maximum 70 characters)
SSID Set or part identifier.
(Integer)
SSTYP Input set type.
= 0
Segment set ID.
= 1
Shell element set ID.
= 2
Part set ID.
= 3
Part ID.
= 5
All parts (SID is ignored).
= 6
Part set ID. All parts are included in the contact, except the one defined in the part set ID.
= 7
Subset set ID.
(Integer)
FS Static friction coefficient.
(Real)
FD Dynamic friction coefficient.
(Real)
DC Exponential decay coefficient. [ s m ] MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaamWaaeaada WcaaqaaiaadohaaeaacaWGTbaaaaGaay5waiaaw2faaaaa@39E3@
Tstart Start time.
(Real)
[ s ]
Tstop Stop time.
Default = 1E+30 (Real)
[ s ]
SST Stiffness scale factor.
(Real)
SFS Maximum gap value.
(Real)
[ m ]
SFTS Contact gap scale.
(Real)
FSF Coulomb friction coefficient scale factor.
SOFT Contact stiffness definition flag.
= 0
Contact stiffness is the average of the main and secondary stiffness.
> 0
Contact stiffness is the minimum of the main and secondary stiffness.
(Integer)
  1. This keyword maps to /INTER/TYPE25.
