*ELEMENT_BEAM
LS-DYNA Input Interface KeywordDefines a beam, discrete beam, or a truss element.
(1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
*ELEMENT_BEAM_{OPTION} | |||||||
EID | part_ID | N1 | N2 | N3 |
VX | VY | VZ |
Definition
OPTION |
EID | Element identifier. (Integer) |
part_ID | Part identifier. (Integer) |
N1, N2, N3 | Node identifier. (Integer) |
VX, VY, VZ | Vector to define cross section orientation. When used the
input for N3 is ignored. (Real) |
