*MAT_027 (MOONEY-RIVLIN_RUBBER)
LS-DYNA Input Interface KeywordDefines a Mooney-Rivlin isotropic hyperelastic incompressible material.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *MAT_027 or *MAT_MOONEY-RIVLIN_RUBBER | |||||||
| mat_ID | A | B | |||||
| Length | Width | Thickness | LCID | ||||
Definition
| mat_ID | Material identifier. (Integer) |
| Initial density. (Real) |
| A, B | Mooney-Rivlin Material constants. (Real) |
| Poisson’s ratio. (Real) |
| Length | Sample length. (Real) |
| Width | Sample width. (Real) |
| Thickness | Sample thickness. (Real) |
| LCID | Function identifier of Force versus
elongation. (Integer) |
- This maps to /MAT/LAW69, if LCID is defined otherwise it maps to /MAT/LAW42 (OGDEN).
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
