*INCLUDE_TRANSFORM
LS-DYNA Input Interface KeywordDefines an include file with transformation.
(1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
*INCLUDE_TRANSFORM | |||||||
file_name | |||||||
IDNOFF | IDEOFF | IDPOFF | IDMOFF | IDSOFF | IDFOFF | IDDOFF | |
IDROFF | PREFIX | SUFFIX | |||||
FCTMAS | FCTTIM | FCTLEN | |||||
TRANID |
file_name | Filename and path of the file to be
included. (Character) |
IDNOFF | Offset value node
ID’s. (Integer) |
IDEOFF | Offset value for element
ID’s. (Integer) |
IDPOFF | Offset value for part ID, nodal
rigid body ID, constrained nodal set ID, rigidwall ID and
cross-section ID. (Integer) |
IDMOFF | Offset value for
*MAT and *EOS
ID’s. (Integer) |
IDSOFF | Offset value for
*SET ID’s. (Integer) |
IDFOFF | Offset value for
*DEFINE_FUNCTION,
*DEFINE_TABLE and
*DEFINE_CURVE
ID’s. (Integer) |
IDDOFF | Offset value for other
DEFINE ID’s. (Integer) |
IDROFF | Offset value for other entity
ID’s. (Integer) |
PREFIX | Prefix added at the beginning of
the entity title defined in the include. Character “.” is added after the prefix. (Text) |
SUFFIX | Suffix added at the end of the
entity title defined in the include. Character “.” is added before the suffix. (Text) |
FCTMAS | Mass scale factor. Default = 1 (Real) |
FCTTIM | Time scale factor. Default = 1 (Real) |
FCTLEN | Length scale factor. Default = 1 (Real) |
TRANID | Defined transformation
ID. (Integer) |
- This keyword maps to //SUBMODEL and /UNIT.
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
