*MAT_083 (FU_CHANG_FOAM)
LS-DYNA Input Interface KeywordDefines an isotropic, highly compressible Fu Chang foam.
(1) (2) (3) (4) (5) (6) (7) (8)
*MAT_083 or *MAT_FU_CHANG_FOAM
mat_ID ρ i E   TBID
        HU
        SHAPE
Definition
mat_ID Material identifier.
(Integer)
ρ i Initial density.
(Real)
[ kg m 3 ]
E Young’s modulus.
(Real)
[ Pa ]
TBID Table identifier for engineering stress versus engineering strain for different strain rates. Positive strains and stresses correspond to compression.
(Real)
HU Hysteresis unloading factor.
0 < HU < 1
(Real)
SHAPE Shape unloading factor.
(Real)
  1. This keyword maps to /MAT/LAW90.
  2. The unloading follows the first loading curve when HU = 0. For HU > 0, the first loading curve is used to calculate the unloading path based on a damage formulation.
  3. The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
