*CONTROL_TIMESTEP
LS-DYNA Input Interface KeywordDefines time step control conditions.
(1) (2) (3) (4) (5) (6) (7) (8)
*CONTROL_TIMESTEP
  TSSFAC     DT2MS
Definition
TSSFAC Scaling coefficient for the time step.
(Real)
DT2MS
< 0
Minimum constant nodal time step.
(Real)
[ s ]
  1. This keyword maps to /DT/NODE/CST.
