*INITIAL_VELOCITY_GENERATION
LS-DYNA Input Interface KeywordDefine both translational and rotational initial velocities.
(1) (2) (3) (4) (5) (6) (7) (8)
ID STYP OMEGA VX VY VZ
XC YC ZC NX NY NZ   IRIGID
Definition
ID
If STYP = 1
Part set identifier.
If STYP = 2
Part identifier.
If STYP = 3
Node set identifier.
(Integer)
STYP Identifier type to apply the initial velocities.
= 1 (Default)
ID is a Part set identifier.
= 2
ID is a Part identifier.
= 3
ID is a Node set identifier.
(Integer)
OMEGA Axial rotational velocity.
(Real)
[ rad s ]
VX, VY, VZ Translational velocity.
(Real)
[ m s ] MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaamWaaeaada Wcaaqaaiaab2gaaeaacaqGZbaaaaGaay5waiaaw2faaaaa@39DE@
XC, YC, ZC Position of the rotational axis.
(Real)
[ m ]
NX, NY, NZ Direction cosines for the rotational axis.
(Real)
IRIGID
Initial velocity for PART_INERTIA and *CONSTRAINED_NODAL_RIGID_BODY_INERTIA.
= 0
Initial velocity is defined in PART_INERTIA and *CONSTRAINED_NODAL_RIGID_BODY_INERTIA.
= 1
Initial velocity is defined in *INITIAL_VELOCITY_GENERATION.
(Integer)
  1. This keyword maps to /INIVEL/AXIS.
