/MAT/LAW57 (BARLAT3)
Block Format Keyword This law describes plasticity hardening by a user-defined function and can be used only with shell elements.
This is an elasto-plastic orthotropic law for modeling anisotropic materials in forming processes especially aluminum alloys. This material law must be used with property set type /PROP/TYPE9 (SH_ORTH) or /PROP/TYPE10 (SH_COMP).
| /MAT/LAW57/mat_ID/unit_ID or /MAT/BARLAT3/mat_ID/unit_ID | |||||||||
| mat_title | |||||||||
| E | |||||||||
| fct_IDE | Einf | CE | |||||||
| r00 | r45 | r90 | Chard | m | |||||
| Fcut | Fsmooth | ||||||||
| fct_IDi | Fscalei | ||||||||
| mat_ID | Material identifier. (Integer, maximum 10 digits) |
| unit_ID | Unit Identifier. (Integer, maximum 10 digits) |
| mat_title | Material title. (Character, maximum 100 characters) |
| Initial density. (Real) |
| E | Young's modulus. (Real) |
| Poisson's ratio. (Real) |
| fct_IDE | Function identifier for the scale factor
of Young's modulus, when Young's modulus is function of the plastic strain. 11 Default = 0: in this case the evolution of Young's modulus depends on Einf and CE. (Integer) |
| Einf | Saturated Young's modulus for infinitive
plastic strain. (Real) |
| CE | Parameter for Young's modulus
evolution. (Real) |
| r00 | Lankford parameter 0 degree. Default = 1.0 (Real) |
| r45 | Lankford parameter 45 degrees. Default = 1.0 (Real) |
| r90 | Lankford parameter 90 degrees. Default = 1.0 (Real) |
| Chard | Hardening coefficient.
(Real) |
| m | Barlat parameter.
(Real) |
| Failure plastic strain. Default = 1.0 x 1030 (Real) |
| Tensile failure strain at which stress
starts to reduce. Default = 1.0 x 1030 (Real) |
| Maximum tensile failure damage strain at
which the stress in element is set to zero. Default = 2.0 x 1030 (Real) |
| Fcut | Cutoff frequency for the strain rate
filtering. Default = 10000 Hz (Real) |
| Fsmooth | Smooth strain rate option flag.
| fct_IDi | Plasticity curves
ith function identifier. (Integer) |
| Fscalei | Scale factor for
ith function. Default set to 1.0 (Real) |
| Strain rate for
ith function. (Real) |
Example (Steel)
#RADIOSS STARTER
/UNIT/1
unit for mat
g mm ms
#- 2. MATERIALS:
/MAT/LAW57/1/1
Steel
# RHO_I
.008
# E NU
206000 .3
#FUNCT_IDE EINF CE
0 0 0
# r00 r45 r90 C_hard m
1.79 1.51 2.27 0 0
# EPSP_max EPS_T EPS_M Fcut Fsmooth
0 0 0 10 1
# funct_ID Fscale_i EPS_i
5 0 0
5 0 1
#- 3. FUNCTIONS:
/FUNCT/5
function_5
# X Y
0 157
.1 320
.5 480
1.2 600
#ENDDATA
/END
#---1----|----2----|----3----|----4----|----5----|----6----|----7----|----8----|----9----|---10----|Comments
- The anisotopic yield criteria
F for plane stress is defined by:
(1) Where,
is the yield stress
and
- Angles for Lankford parameters are defined with respect to orthotropic direction 1.
The material constants a, c, h, and
p are obtained from the three Lankford parameters:
(2) Material constant p is calculated by solving:(3) - If the last point of the first (static) function equals 0 in stress, the default value of is set to the corresponding value of .
- If (plastic strain) reaches , in one integration point, the corresponding shell element is deleted.
- If the largest principal strain
, the stress is reduced using the following
relation:
(4) - If , the stress is reduced to 0 (but the element is not deleted).
- The maximum number of curves is 10.
- If , the yield is interpolated between fn and fn-1.
- If , function f1 is used.
- Above
, yield is extrapolated.
Figure 1. - The evolution of
Young's modulus:
- If fct_IDE > 0, the curve defines a scale factor for Young's modulus evolution with equivalent
plastic strain, which means the Young's modulus is scaled by the function
(5) The initial value of the scale factor should be equal to 1 and it decreases.
- If fct_IDE = 0, the Young's modulus is calculated as:
(6) Where, E and Einf are respectively the initial and asymptotic value of Young's modulus, and is the accumulated equivalent plastic strain.
Note: If fct_IDE = 0 and CE = 0, Young's modulus, E is kept constant.
- The parameters Fsmooth and Fcut
allows you to enable a strain-rate filtering. Three cases can be set:
- If Fsmooth = 0 and Fcut = 0.0, the strain-rate filtering is turned off.
- If Fsmooth = 1 and Fcut = 0.0, the strain-rate filtering uses a default cutoff frequency of 10 kHz.
- If Fcut ≠ 0, Fsmooth is automatically set to 1 and the strain-rate filtering uses the cutoff frequency given by you.
