/MAT/LAW79 (JOHN_HOLM)
Block Format Keyword This material law describes the behavior of brittle materials, such as ceramics and glass. The implementation is the second Johnson-Holmquist model: JH-2.
| /MAT/LAW79/mat_ID/unit_ID or /MAT/JOHN_HOLM/mat_ID/unit_ID | |||||||||
| mat_title | |||||||||
| G | |||||||||
| a | b | m | n | ||||||
| c | |||||||||
| T | HEL | PHEL | |||||||
| D1 | D2 | ||||||||
| K1 | K2 | K3 | |||||||
| mat_ID | Material
| unit_ID | Unit Identifier (Integer, maximum 10 digits) |
| mat_title | Material
| Initial
density (Real) |
| Reference density
used in E.O.S (equation of state). Default = (Real) |
| G | Shear
modulus (Real) |
| a | Intact normalized
strength constant. 1 (Real) |
| b | Fractured
normalized strength constant. 1 (Real) |
| m | Fractured strength
pressure exponent. 1 (Real) |
| n | Intact strength
| c | Strain rate coefficient.
(Real) |
| Reference strain
rate. Usually = 1 (Real) |
| Maximum normalized
fractured strength. Default = 1030 (Real) |
| T | Maximum pressure
tensile strength. Default = 1030 (Real) |
| HEL | Hugoniot elastic
limit. (Real) |
| PHEL | Pressure at
Hugoniot elastic limit. (Real) |
| D1 | Damage constant.
2 (Real) |
| D2 | Damage exponent.
2 (Real) |
| K1 | Bulk
modulus. (Real) |
| K2 | Pressure
coefficient. 3 (Real) |
| K3 | Pressure
| Bulking pressure
coefficient
. (Real) |
Input Example
Example (AL2O3)
#RADIOSS STARTER
/UNIT/1
unit for mat
g mm ms
#- 2. MATERIALS:
/MAT/LAW79/1/1
Al2O3
# RHO_I RHO_0
.0037 0
# G
90160
# a b m n
.93 0 0 .6
# c EPS0 SIGMA_FMAX
0 .001 1E-30
# T HEL PHEL
200 2790 1460
# D1 D2
0 0
# K1 K2 K3 BETA
130950 0 0 1
#ENDDATA
/END
- The equation
describing the normalized equivalent stress is:
(1) with the equivalent stress of the intact material:(2) and the equivalent stress of the failed material:(3) Stress are normalized to the stress at the Hugoniot elastic limit:(4) and pressure are normalized to PHEL:
and
- The accumulated
damage is:
(5) where, the plastic strain to failure is:(6) - The Equation of
state is:
(7) Where, the bulking pressure is computed as a function of the elastic energy loss converted into potential hydrostatic energy:(8) - Time history and
animation output is available using these USRi variables:
- USR3: Damage D
- USR4: Bulking Pressure
- USR5: Yield Stress
