Radioss
Radioss
2022
  1. Home
  2. Reference Guide
  3. Starter Input
  4. Materials
  5. Equation of State
    Used by Radioss to compute the hydrodynamic pressure.
  • What's New
  • Overview
  • Tutorials
  • User Guide
  • Reference Guide
  • Example Guide
  • Verification Problems
  • Frequently Asked Questions
  • Theory Manual
  • User Subroutines
  • Starter Input
  • Engine Input
Index
Radioss
2022
Radioss
  • What's New
    View new features for Radioss 2022.
  • Overview
  • Tutorials
  • User Guide
  • Reference Guide
    • File Extensions and Formats
      Radioss format 2022 uses the 12x extension format.
    • Single File Input
    • New Keywords in 2022
    • Starter Input
      • 2D and 3D Analysis Options
      • Starter Keywords Syntax
        Block Format Keyword
      • Smooth Particle Hydrodynamics (SPH)
      • Computational Fluid Dynamics (CFD)
      • General Controls
        Block Format Keyword In this group, keywords are used to set default value, global parameter, analysis type, input/output print, damping and ALE and CFD treatment for the whole model. For default value, it is still possible to overwrite in each specific keywords.
      • Nodes
        Block Format Keyword In Radioss, two node types are available. They use Cartesian coordinate to describe the position of each node.
      • Elements
      • Component and Parts Organization
        Block Format Keyword In this group, keywords are used to combine material and property information (/PART), assemble model (/SUBSET) or define a separate model (//SUBMODEL).
      • Interfaces
        Block Format Keyword Interfaces solve the contact and impact conditions between two parts of a model. Several interface types are available in Radioss and use different contact treatments.
      • Materials
        • Material Compatibility
          Block Format Keyword The following tables list the compatibility options for each of the material laws.
        • Elasto-plastic Materials
          These materials can be used to represent elasto-plastic materials.
        • Hyper and Visco-elastic Materials
          These materials can be used to represent hyper and visco-elastic materials.
        • Composite and Fabric Materials
          These materials can be used to represent composite and fabric materials.
        • Multiscale Materials
        • Concrete and Rock Materials
          In Radioss these materials can be used to represent rock or concrete materials.
        • Honeycomb Materials
          These materials can be used to represent honeycomb materials.
        • Connection Materials
          These materials can be used to represent connection materials.
        • Other Materials
          These materials can be used to represent other materials.
        • Multi-Material, Fluid and Explosive Materials
          These materials can be used to represent multi-material, fluid and explosive materials.
        • ALE and CFD Options
          Block Format Keyword ALE and CFD options used to activate ALE formulation or Eulerian formulation for a given material law.
        • Viscosity Option
        • Leakage Option
        • Thermal Option
        • Equation of State
          • /EOS/COMPACTION
            Block Format Keyword Describes pressure for a porous media such as soil or foam which can be compacted and unloaded.
          • /EOS/GRUNEISEN
            Block Format Keyword Describes the Gruneisen equation of state.
          • /EOS/IDEAL-GAS or /EOS/IDEAL-GAS-VE
            Block Format Keyword Describes the ideal gas equation of state .
          • /EOS/IDEAL-GAS-VT
            Block Format Keyword Describes the equation of state for ideal gas (volume - temperature).
          • /EOS/LINEAR
            Block Format Keyword Describes the linear equation of state with initial pressure and bulk modulus.
          • /EOS/LSZK
            Block Format Keyword Describes the Landau-Stanyukovich-Zeldovich-Kompaneets EOS for detonation products.
          • /EOS/MURNAGHAN
            Block Format Keyword Describes the Murnaghan equation of state.
          • /EOS/NASG
            Block Format Keyword Describes the NASG (Noble-Abel-Stiffened-Gas) equation of state.
          • /EOS/NOBLE-ABEL
            Block Format Keyword Describes the covolume equation of state .
          • /EOS/OSBORNE
            Block Format Keyword Describes the Osborne Equation of State from R.K. Osborne, also called the “quadratic EOS”.
          • /EOS/POLYNOMIAL
            Block Format Keyword Describes the linear polynomial equation of state .
          • /EOS/PUFF
          • /EOS/SESAME
            Block Format Keyword Describes the SESAME table equation of state.
          • /EOS/STIFF-GAS
            Block Format Keyword Describes the ideal gas equation of state for stiffed gas .
          • /EOS/TILLOTSON
            Block Format Keyword Describes the Tillotson equation of state.
        • Failure Models
          The supported failure models in Radioss.
      • Properties
      • Monitored Volumes (Airbags)
        Block Format Keyword Monitored volumes can be used to model an airbag, tire, tank, or any closed volume.
      • Constraints
        Block Format Keyword Radioss supports several different kinematic constraints, which are mainly used to impose acceleration, velocity, displacement or temperature in structure or constraint the moving of structure. They are mutually exclusive for each degree-of-freedom (DOF). Two kinematic conditions applied to the same node may be incompatible.
      • Load Cases
        Block Format Keyword In Radioss the following load cases are available. Stress/strain as initial state could be considered by modeling, as well as pressure, gravity, and thermal load.
      • Tools
        Block Format Keyword In this group, tools like transformation, frames, skews, and curve are introduced.
      • Groups(Sets)
      • Adaptive Meshings
        Block Format Keyword Adaptive Meshing is used in metal forming to divide the element to better describe the geometry. /ADMESH/GLOBAL and /ADMESH/SET are not available for SPMD computation.
      • Output Database
        Block Format Keyword Time histories output for different element groups, section output, or gauge output are described in this group.
      • Obsolete
        Block Format Keyword Keywords that are still supported, but no longer maintained (*) are considered obsolete.
    • Engine Input
    • LS-DYNA Input
      This manual contains an alphabetical list of LS-DYNA input files available in Radioss.
    • Optimization Keywords
    • Multi-Domain
      This manual contains the description of the Keywords for the Radioss Multi-Domain.
    • Other Files
    • Definitions
  • Example Guide
  • Theory Manual
  • User Subroutines
  • Starter Input
  • Engine Input
View All Altair Simulation Help
Radioss
Radioss
2022
  1. Home
  2. Reference Guide
  3. Starter Input
  4. Materials
  • What's New
  • Overview
  • Tutorials
  • User Guide
  • Reference Guide
  • Example Guide
  • Theory Manual
  • User Subroutines
  • Starter Input
  • Engine Input
Index
Equation of State
Compatibility
EOS is used by Radioss to compute the hydrodynamic pressure and is compatible with the material laws:
  • /MAT/LAW3 (HYDPLA)
  • /MAT/LAW4 (HYD_JCOOK)
  • /MAT/LAW6 (HYDRO or HYD_VISC)
  • /MAT/LAW10 (DPRAG1)
  • /MAT/LAW12 (3D_COMP)
  • /MAT/LAW49 (STEINB)
  • /MAT/LAW102 (DPRAG2)
  • /MAT/LAW103 (HENSEL-SPITTEL)
Supported Keywords
  • /EOS/COMPACTION
  • /EOS/GRUNEISEN
    Block Format Keyword Describes the ideal gas equation of state P = ( γ − 1 ) ( 1 + μ ) E MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaqaaaaaaaaa WdbiaadcfacqGH9aqpdaqadaWdaeaapeGaeq4SdCMaeyOeI0IaaGym aaGaayjkaiaawMcaamaabmaapaqaa8qacaaIXaGaey4kaSIaeqiVd0 gacaGLOaGaayzkaaGaamyraaaa@4316@ .
  • /EOS/IDEAL-GAS-VT
  • /EOS/LINEAR
    Block Format Keyword Describes the linear equation of state P ( μ ) = P 0 + B μ MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGqbWaae WaaeaacqaH8oqBaiaawIcacaGLPaaacqGH9aqpcaWGqbWaaSbaaSqa aiaaicdaaeqaaOGaey4kaSIaamOqaiabeY7aTbaa@41A6@ with initial pressure and bulk modulus.
  • /EOS/LSZK
  • /EOS/MURNAGHAN
  • /EOS/NASG
  • /EOS/NOBLE-ABEL
    Block Format Keyword Describes the covolume equation of state P ( v − b ) = R T .
  • /EOS/OSBORNE
  • /EOS/POLYNOMIAL
    Block Format Keyword Describes the linear polynomial equation of state P ( ρ , E ) .
  • /EOS/PUFF
  • /EOS/SESAME
  • /EOS/STIFF-GAS
    Block Format Keyword Describes the ideal gas equation of state for stiffed gas P ( μ , E ) = ( γ − 1 ) ( 1 + μ ) E − γ P * MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaqaaaaaaaaa WdbiaadcfadaqadaWdaeaapeGaeqiVd0MaaiilaiaadweaaiaawIca caGLPaaacqGH9aqpdaqadaWdaeaapeGaeq4SdCMaeyOeI0IaaGymaa GaayjkaiaawMcaamaabmaapaqaa8qacaaIXaGaey4kaSIaeqiVd0ga caGLOaGaayzkaaGaamyraiabgkHiTiabeo7aNjaadcfadaahaaWcbe qaaiaacQcaaaaaaa@4C31@ .
  • /EOS/TILLOTSON
