/MAT/LAW10 (DPRAG1)
Block Format Keyword This law, based on an extended Drücker-Prager yield criteria, is used to model materials with internal friction such as rock-concrete.
/MAT/LAW10/mat_ID/unit_ID or /MAT/DPRAG1/mat_ID/unit_ID | |||||||||
mat_title | |||||||||
E | |||||||||
A0 | A1 | A2 | Amax | ||||||
mat_ID | Material
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
mat_title | Material
Initial
density. (Real) |
E | Young's
modulus. (Real) |
Poisson's
ratio. (Real) |
A0 | Yield criteria
coefficient. (Real) |
A1 | Yield criteria
A2 | Yield criteria
Amax | Yield criteria limit (von
Mises limit). (Real) |
Minimum
pressure. Default = -1030 (Real) |
Example (Concrete)
#RADIOSS STARTER
/UNIT/1
unit for mat
g cm mus
#- 2. MATERIALS:
/MAT/LAW10/1/1
Concrete
# RHO_I
2.4
# E Nu
.576 .25
# A0 A1 A2 Amax
9.72E-10 4.32E-5 .48 .013
# P_min
-1E-20
/EOS/COMPACTION/1/1
Concreate EOS
# C0 C1 C2 C3
0.0 0.256 0.256 1
# MUMIN MUMAX BUNL
0.0 0.44 0.115
# PSH RHO0
0 2.40
#ENDDATA
- Original Drücker-Prager
yield criterion has a linear pressure dependency.
Figure 1. Original Drücker-Prager Yield CriteriaRadioss is using the extended Drücker-Prager yield criteria whose pressure dependency is nonlinear.
Figure 2. Extended Drücker-Prager Yield Criteria Implemented in Radioss - Extended Drücker-Prager
yield criteria can be compared with Mohr-Coulomb criteria.
Figure 3. Extended Drücker-Prager Yield Criteria Implemented in Radioss versus Mohr-Coulomb CriteriaAn extended Drücker-Prager yield criterion can be fitted from Mohr-Coulomb parameters:- Cohesion parameter
- Angle of internal friction
For this purpose, parameters must be defined as:(1) - Modeling Type
- Parameters
- Circumscribed Drücker-Prager criteria
- Middle Circle
- Inscribed Drücker-Prager criteria
Figure 4. Fitting a Drücker-Prager Yield Criteria (blue colors) from Mohr-Coulomb Criterion (black) - /MAT/LAW21 is also based on an extended Drücker-Prager yield criteria but pressure evolution can be described with user functions.
- Young's modulus E and Poisson’s ratio are used to determined shear modulus G which is required for sound speed calculation in solid materials.
