Block Format Keyword In this group, keywords are used to set default value, global parameter, analysis type, input/output print,
damping and ALE and CFD treatment for the whole model. For default value, it is still possible to overwrite in each
specific keywords.
Block Format Keyword In this group, keywords are used to combine material and property information (/PART), assemble model (/SUBSET) or define a separate model (//SUBMODEL).
Block Format Keyword Interfaces solve the contact and impact conditions between two parts of a model. Several interface types are available
in Radioss and use different contact treatments.
Block Format Keyword This keyword defines an isotropic, linear elastic material using Hooke's law. This law represents a linear relationship
between stress and strain. It is available for truss, beam (type 3 only), shell and solid elements.
Block Format Keyword This law describes the behavior of superelastic materials. It allows modeling the behavior of the shape memory alloys
(such as Nitinol).
Block Format Keyword Describes the P-α porous material model. This material describes ductile Porous material with Herrmann
model. It only works with 8-node brick element and is not compatible with ALE.
Block Format Keyword This spring material works with six independent modes of deformation and accounts for nonlinear stiffness, damping
and different unloading.
Block Format Keyword This beam type spring material works as a beam element with six independent modes of deformation. This spring accounts
for nonlinear stiffness, damping and different unloading.
Block Format Keyword Radioss supports several different kinematic constraints, which are mainly used to impose acceleration, velocity, displacement
or temperature in structure or constraint the moving of structure. They are mutually exclusive for each degree-of-freedom
(DOF). Two kinematic conditions applied to the same node may be incompatible.
Block Format Keyword In Radioss the following load cases are available. Stress/strain as initial state could be considered by modeling, as well as
pressure, gravity, and thermal load.
Block Format Keyword Adaptive Meshing is used in metal forming to divide the element to better describe the geometry. /ADMESH/GLOBAL and /ADMESH/SET are not available for SPMD computation.
These materials can be used to represent other materials.
/MAT/LAW0 (VOID) Block Format Keyword This material can be used to define elements to act as a void, or an empty space.
/MAT/LAW1 (ELAST) Block Format Keyword This keyword defines an isotropic, linear elastic material using Hooke's law. This law represents a linear relationship between stress and strain. It is available for truss, beam (type 3 only), shell and solid elements.
/MAT/LAW71 Block Format Keyword This law describes the behavior of superelastic materials. It allows modeling the behavior of the shape memory alloys (such as Nitinol).
/MAT/LAW75 (POROUS) Block Format Keyword Describes the P-α porous material model. This material describes ductile Porous material with Herrmann model. It only works with 8-node brick element and is not compatible with ALE.
/MAT/LAW108 (SPR_GENE) Block Format Keyword This spring material works with six independent modes of deformation and accounts for nonlinear stiffness, damping and different unloading.
/MAT/LAW113 (SPR_BEAM) Block Format Keyword This beam type spring material works as a beam element with six independent modes of deformation. This spring accounts for nonlinear stiffness, damping and different unloading.
/MAT/GAS Block Format Keyword Describes the gas molecular weight and specific heat coefficients.
/MAT/USERij Block Format Keyword This law describes the user material.
