/MAT/LAW75 (POROUS)
Block Format Keyword Describes the P-α porous material model. This material describes ductile Porous material with Herrmann model. It only works with 8-node brick element and is not compatible with ALE.
/MAT/LAW75/mat_ID/unit_ID or /MAT/POROUS/mat_ID/unit_ID | |||||||||
mat_title | |||||||||
E | |||||||||
mat_IDs | Iflag1 | Iflag2 | itemax | ||||||
PE | Ps | n | |||||||
tol |
mat_ID | Material identifier (Integer, maximum 10 digits) |
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
mat_title | Material title (Character, maximum 100 characters) |
Initial density for porous
material (Real) |
E | Young's modulus (Real) |
Poisson's ratio (Real) |
mat_IDs | Material identifier of the solid (fully
compacted) material. (Integer) |
Iflag1 | Pressure formulation flag.
(Integer) |
Iflag2 | Deviatoric stresses formulation flag.
(Integer) |
itemax | Maximum number of iterations on a
calculation. Default = 5 (Integer) |
PE | Elastic compact pressure (elastic
limit). 3 (Real) |
Ps | Solid (matrix) compact pressure. 3 (Real) |
n | Exponent used for fitting the experiment
data. 3 Default = 2 (Real) |
tol | Convergence tolerance on a calculation.
Default = 10-8 (Real) |
Example (Porous Soil)
#- 2. LOCAL_UNIT_SYSTEM:
/UNIT/1
unit for mat
# MUNIT LUNIT TUNIT
g cm mus
#- 1. MATERIALS:
/MAT/LAW75/1/1
porous soil
# RHO_I
1.7
# E NU
3 .3
# MAT_IDs IFLAG1 IFLAG2 ITEMAX
2 1 2 0
# PE PS N
.01 .05 0
# TOL
0
/MAT/HYD_JCOOK/2/1
soil
# RHO_I RHO_O
1.76000004 0
# E nu
3.5999999 .300000012
# A B n epsmax sigmax
10000 0 0 0 0
# Pmin
0
# C EPS_DOT_0 M Tmelt Tmax
0 0 0 0 0
# RHOCP Troom
0 0
/EOS/POLYNOMIAL/2/1
EOS for soil
# C0 C1 C2 C3
0 2.81999993 2 -1.37
# C4 C5 E0 Psh RHO_0
1.53999996 1.53999996 0 0 0
#enddata
- The porosity α is defined as:
(1) Note that α ≥ 1 ( )
Where,- Density of the solid (full compacted matrix) material
- Density of the porous material
- If the EOS of the solid (matrix)
material is:
(2) Then the EOS of the porous material is:- for Herrmann formulation
- for modified Herrmann formulation
Where, ( ) is the internal energy per unit mass. It is same in porous material and in the solid (matrix) material.
- If
the behavior is elastic, and if
describes plastic region.
In the elastic region, the change of porosity α with pressure is reversible.
In the plastic region, the porosity α is assumed to depend on pressure as described below:(3) Where,- Porosity where pressure reach the elastic compact pressure
- Pressure reaches the solid (matrix) compact pressure
- Iinitial porosity
