/EOS/GRUNEISEN
Block Format Keyword Describes the Gruneisen equation of state.
/EOS/GRUNEISEN/mat_ID/unit_ID | |||||||||
eos_title | |||||||||
C | S1 | S2 | S3 | ||||||
a | E0 |
mat_ID | Material identifier. (Integer, maximum 10 digits) |
unit_ID | Unit Identifier. (Integer, maximum 10 digits) |
eos_title | EOS title. (Character, maximum 100 characters) |
C | C sound speed. 1 (Real) |
S1 | S1
material constant. 1 (Real) |
S2 | S2
material constant. (Real) |
S3 | S3
coefficient. (Real) |
a | a coefficient (see
equation below). Default = (Real) |
E0 | Initial energy per unit reference
volume. (Real) |
Reference density. Default = material density (Real) |
Example (Copper)
#RADIOSS STARTER
/UNIT/1
unit for mat
g cm mus
/MAT/HYD_JCOOK/1/1
Copper (data from Example 46 - TNT Cylinder Expansion Test)
# RHO_I RHO_0
8.96 0
# E nu
1.24 .35
# A B n epsmax sigmax
9E-4 .00292 .31 0 .0066
# Pmin
-1E30
# C EPS_DOT_0 M Tmelt Tmax
.025 1E-6 1.09 1656 1E30
# RHOCP T_r
3.461E-5 0
/EOS/GRUNEISEN/1/1
Copper
# C S1 S2 S3
.394 1.489 0 0
# GAMMA0 ALPHA E0 RHO_0
1.97 .47 0 8.96
#ENDDATA
- C, S1, S2 and S3 are the coefficients of the cubic equation relating the shock velocity to the particle velocity.
- Let
, if
, the pressure is given by:
(1) - If
(2) - Equations of state are used by
Radioss to compute the hydrodynamic pressure and are
compatible with the material laws:
- /MAT/LAW3 (HYDPLA)
- /MAT/LAW4 (HYD_JCOOK)
- /MAT/LAW6 (HYDRO or HYD_VISC)
- /MAT/LAW10 (DPRAG1)
- /MAT/LAW12 (3D_COMP)
- /MAT/LAW49 (STEINB)
- /MAT/LAW102 (DPRAG2)
- /MAT/LAW103 (HENSEL-SPITTEL)
- Input example with units: grams, cm,
(micro-seconds):
Material S1 a Cu 8.9 0.394 1.489 1.97 0.47 Stainless Steel 1 7.9 0.457 1.490 2.00 0.50 Al 2.7 0.533 1.338 2.18 0.48 Al Alloy 2 2.7855 0.533 1.338 2.18 0.48 Be 1.8519 0.8 1.124 1.16 0.16 Mg Alloy 3 1.7794 0.452 1.242 1.63 0.33 Ti 4.5249 0.47 1.146 1.3 0.20 Ni 8.8968 0.465 1.445 2 0.50 Pb 11.3379 0.201 1.54 2.84 0.54
