/EOS/IDEAL-GAS or /EOS/IDEAL-GAS-VE
Block Format Keyword Describes the ideal gas equation of state .
/EOS/IDEAL-GAS/mat_ID/unit_ID or /EOS/IDEAL-GAS-VE/mat_ID/unit_ID | |||||||||
eos_title | |||||||||
P0 | Psh | T0 |
mat_ID | Material
identifier. (Integer, maximum 10 digits) |
unit_ID | Unit Identifier. (Integer, maximum 10 digits) |
eos_title | EOS
title. (Character, maximum 100 characters) |
Heat capacity ratio
. (Real) |
P0 | Initial
pressure. (Real) |
Psh | Pressure
shift. (Real) |
T0 | Initial
temperature. (Real) |
Reference
density. Default = material density (Real) |
/UNIT/1
unit for mat
g mm ms
/MAT/HYDRO/7/1
AIR
# RHO_I RHO_0
1.22e-6 0
# Knu Pmin
1.5E-2 0
/EOS/IDEAL-GAS/7/1
EoS for Air at atmospheric pressure
# GAMMA P0 PSH T0 RHO0
1.4 0.10 0 300.0 1.22E-6
/ALE/MAT/7
#enddata
- Ideal-gas thermal EOS is:
(1) Where,- Specific volume
- Specific gas constant
- Temperature
Previous form of can be written in the form.
Where,(2) (3) (4) with(5) Where, and are constant parameters.
Consequently, the same equation of state can be built using /EOS/IDEAL-GAS-VT (Volume Temperature) defining the special case of a constant function:(6) - Some characteristics of this equation of state:
- Ideal Gas
- Sounce speed
- For this equation of state,
and
In other cases, /EOS/IDEAL-GAS-VT (Volume Temperature) must be used.
The heat capacity is computed from the initial data:(7) This parameter enables the calculation of the gas temperature since(8) Where,- Specific energy by mass
- Equations of state are used by
Radioss to compute the hydrodynamic pressure and are
compatible with the material laws:
- /MAT/LAW3 (HYDPLA)
- /MAT/LAW4 (HYD_JCOOK)
- /MAT/LAW6 (HYDRO or HYD_VISC)
- /MAT/LAW10 (DPRAG1)
- /MAT/LAW12 (3D_COMP)
- /MAT/LAW49 (STEINB)
- /MAT/LAW102 (DPRAG2)
- /MAT/LAW103 (HENSEL-SPITTEL)
