/EULER/MAT
Block Format Keyword Compute material flow with EULER framework.
/EULER/MAT/mat_ID
mat_ID Material identifier.
(Integer, maximum 10 digits)
Example (Air)
#RADIOSS STARTER
/UNIT/1
unit for mat
                  kg                   m                   s
/MAT/HYDRO/4/1
AIR
#              RHO_I               RHO_0
                1.22                   0
#                Knu                Pmin
              1.5E-5                   0
/EOS/POLYNOMIAL/4/1
AIR
#                 C0                  C1                  C2                  C3
                   0                   0                   0                   0
#                 C4                  C5                  E0                Pmin               RHO_0
                 0.4                 0.4              253300                   0                1.22
/EULER/MAT/4
#enddata
/END
  1. There is no convection through a boundary face.
  2. With a collocated scheme (/MAT/LAW151 (MULTIFLUID)) there is by default a slipping wall boundary condition ( υ n n = υ w a l l n MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqipu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyXdu3aaS baaSqaaiaad6gaaeqaaOGaeyyXICTaaCOBaiabg2da9iabew8a1naa BaaaleaacaWG3bGaamyyaiaadYgacaWGSbaabeaakiabgwSixlaah6 gaaaa@460F@ ).
  3. With a staggered scheme (all material laws, except /MAT/LAW151) velocity must be fixed with /BCS option at boundary nodes. You can define either a solid wall boundary condition ( υ f = υ w a l l MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqipu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyXdu3aaS baaSqaaiaadAgaaeqaaOGaeyypa0JaeqyXdu3aaSbaaSqaaiaadEha caWGHbGaamiBaiaadYgaaeqaaaaa@3F7B@ ) or a slipping wall boundary condition ( υ f n = υ w a l l n MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqipu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyXdu3aaS baaSqaaiaadAgaaeqaaOGaeyyXICTaaCOBaiabg2da9iabew8a1naa BaaaleaacaWG3bGaamyyaiaadYgacaWGSbaabeaakiabgwSixlaah6 gaaaa@4607@ ).
  4. To define outlet/inlet, refer to /EBCS (or material boundaries: /MAT/LAW11 (BOUND), /MAT/LAW51 (MULTIMAT)).
