/MAT/LAW51 (MULTIMAT)
Block Format Keyword Up to four material laws can be defined: elasto-plastic solid, liquid, gas and detonation products. The material law is based on a diffusive interface technique to get sharper interfaces between submaterial zone (/ALE/MUSCL in Radioss Starter Input).
It is not recommended to use this law with Radioss single precision engine.
| /MAT/LAW51/mat_ID/unit_ID | |||||||||
| mat_title | |||||||||
| Blank | |||||||||
| Iform | |||||||||
Formulation Types
| Formulation | Number of Sub-materials | Plasticity | Explosive |
| Iform = 0 | 3 | -- | -- |
| Iform = 1 | 3 | Johnson-Cook | -- |
| Iform = 10 | 4 | Johnson-Cook | Jones-Wilkins-Lee |
| Iform = 11 | 4 | Johnson-Cook Drücker-Prager |
Jones-Wilkins-Lee |
| Iform = 12 | 5 | Johnson-Cook Drücker-Prager |
Jones-Wilkins-Lee |
Outlet formulation (Iform=3) is obsolete since 2018.0 version. It is replaced by new Non-Reflecting-Frontier (Iform = 6)
Modeling Technique with Polynomial EOS
| Material Hypothesis | Output | Modeling | ||||||||
| C0 | C1 | C2 | C3 | C4 | C5 | E0 | Pext | Pmin | ||
| Perfect gas (Example 43) | ||||||||||
| -P0 | P0 | |||||||||
| Water (Linear EOS) | P0 | |||||||||
| P0 | -P0 | |||||||||
| Elastic Solid (Linear EOS) | P0 | |||||||||
| P0 | ||||||||||
| Mie-Gruneisen constant |
K1 | E0 | P0 | |||||||
| Mie-Gruneisen linear
- Total pressure and total energy formulation
- Relative pressure and total energy formulation
- Total pressure and relative energy formulation
- Relative pressure and relative energy formulation
- P0
- Initial total pressure
- E0
- Initial total energy
- Perfect gas constant
- E
- Young's modulus
- Poisson coefficient
- Gruneisen's gamma
- Coefficient for first order volume correction to the Gruneisen gamma
- c
- Speed of sound
- Initial density
- S
- Linear Hugoniot slope coefficient
- Numerical diffusion can be improved using the second order method for volume fraction convection, /ALE/MUSCL. The previous /UPWIND used to limit diffusion is now obsolete.
- Time step for ALE material laws can be tune with Engine card /DT/ALE; by default, scale factor on time step is 0.5
- This law can emulate /MAT/LAW37 (BIPHAS) (liquid and gas mixture) with less diffusion. It can also replace /MAT/LAW20 (BIMAT) in 2D analysis since /MAT/LAW51 is compatible with QUAD elements.
- /MAT/LAW51 (MULTIMAT) is based on the equilibrium between
each material present inside the element. Radioss
computes and outputs a relative pressure
. At each cycle:
User can deduce total pressure using output value and input parameter :
(5) - Tetra 4 elements can be used for this law, but BRICK elements are currently highly recommended for better numerical solution in ALE.
