/EBCS
Block Format Keyword Describes the elementary boundary condition sets.
/EBCS/type/ebcs_ID/unit_ID
ebcs_title
Type: GRADP0, PRES, VALVIN or VALVOUT
surf_ID
C
fct_IDpr Fscalepr
fct_IDrho Fscalerho
fct_IDen Fscaleen
lc r1 r2
Type: VEL
surf_ID
C
fct_IDvx Fscalevx
fct_IDvy Fscalevy
fct_IDvz Fscalevz
fct_IDrho Fscalerho
fct_IDen Fscaleen
lc r1 r2
Type: NORMV
surf_ID
C
fct_IDvim Fscalevim
fct_IDrho Fscalerho
fct_IDen Fscaleen
lc r1 r2
Type: INIP, INIV
surf_ID
Rho C l c
type Elementary boundary condition keyword.
(see EBCS Type for available keywords)
ebcs_ID Elementary boundary condition identifier.
(Integer, maximum 10 digits)
unit_ID Unit Identifier
ebcs_title Elementary boundary condition title.
surf_ID Surface identifier.
(Integer)
C Speed of sound.
Default = 0 (Real)
[ m s ] MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaamWaaeaada Wcaaqaaiaab2gaaeaacaqGZbaaaaGaay5waiaaw2faaaaa@39DE@
fct_IDpr Function f p r ( t ) identifier for pressure.
= 0
P = F s c a l e p r
= n
P = F s c a l e p r f p r ( t )
(Integer)
Fscalepr Pressure scale factor.
Default = 0 (Real)
[ Pa ]
fct_IDrho Function f r h o ( t ) identifier for density.
= 0
ρ = F s c a l e r h o
= n
ρ = F s c a l e r h o f r h o ( t )
(Integer)
Fscalerho Density scale factor.
Default = 0 (Real)
[ kg m 3 ]
fct_IDen Function f e n ( t ) identifier for energy.
= 0
E = F s c a l e e n
= n
E = F s c a l e e n f e n ( t )
(Integer)
Fscaleen Energy scale factor.
Default = 0 (Real)
[ J ]
l c Characteristic length.
Default = 0 (Real)
[ m ]
r1 Linear resistance. 6
Default = 0 (Real)
[ kg m 2 s ]
r2 Quadratic resistance. 6
Default = 0 (Real)
[ kg m 3 ]
fct_IDvx Function f V X ( t ) identifier for X velocity.
= 0
V X = F s c a l e V X
= n
V X = F s c a l e V X f V X ( t )
(Integer)
Fscalevx X velocity scale factor.
Default = 0 (Real)
[ kg m 3 ]
fct_IDvy Function f V Y ( t ) identifier for Y velocity.
= 0
V Y = F s c a l e V Y
= n
V Y = F s c a l e V Y f V Y ( t )
(Integer)
Fscalevy Y velocity scale factor.
Default = 0 (Real)
fct_IDvz Function f V Z ( t ) identifier for Z velocity.
= 0
V Z = F s c a l e V Z
= n
V Z = F s c a l e V Z f V Z ( t )
(Integer)
Fscalevz Z velocity scale factor.
Default = 0 (Real)
fct_IDvim Function f v i m ( t ) identifier for imposed velocity.
= 0
V = F s c a l e v i m
= n
V = F s c a l e v i m f v i m ( t )
(Integer)
Fscalevim Imposed velocity.
Default = 0 (Real)
Rho Initial density.
Default = 0 (Real)
[ kg m 3 ]
EBCS Type
Table 1. Element Compatibilities with Material
Type Keyword Description
0 GRADP0 Zero pressure gradient. Is not allowed for SPMD parallel version.
1 PRES Imposed density and pressure
2 VALVIN Inlet valve (Imposed density and pressure)
3 VALVOUT Outlet valve (Imposed density and pressure)
4 VEL Imposed velocity
5 NORMV Imposed normal velocity
6 INIP Initial pressure
7 INIV Initial velocity
  1. Input is general, no prior assumptions are enforced! You must verify that the elementary boundaries are consistent with general assumptions of ALE (equation closure).
  2. It is not advised to use the Hydrodynamic Bi-material Liquid Gas Law (/MAT/LAW37 (BIPHAS)) with the elementary boundary conditions.
  3. Density, pressure, energy are imposed according to a scale factor and a time function. If the function number is 0, the imposed density, pressure and energy are used.
  4. All EBCS which type is less tha four or equal to six are non-reflective frontiers (NRF), using:
    (1)
    P t = ρ c V n t + c ( P P ) l c
    Pressure in the far field P is imposed with a function of time. The transient pressure is derived from P , the local velocity field V and the normal of the outlet facet.
    Where, l c is the characteristic length, to compute cutoff frequency f c as:(2)
    f c = c 2 π . l c
  5. In order to impose a positive velocity fct_IDvim (for instance 15 m/s), you must input -fct_IDvim (for instance -15 m/s).
  6. A resistance pressure is computed and added to the current pressure.(3)
    P r e s = r 1 V n + r 2 V n | V n |
    It aims at modeling the friction loss due to the valves.
