/SENSOR/ENERGY
Block Format Keyword Describes the sensors used to activate or deactivate an object according to energy.
/SENSOR/ENERGY/sens_ID/unit_ID
sens_title
Tdelay
part_ID subset_ID
IEmin IEmax KEmin KEmax Tmin
IEtol IEtime KEtol KEtime
Definition
sens_ID Sensor identifier.
(Integer, maximum 10 digits)
unit_ID Optional unit identifier.
sens_title Sensor title.
Tdelay Time delay.
(Real)
[ s ]
part_ID Part identifier for the part monitored for /SENSOR/ENERGY.
(Integer)
subset_ID Subset identifier for the subset monitored for /SENSOR/ENERGY, used if part_ID is not defined.
If part_ID and subset_ID are not defined, global internal and kinetic energy are used.
(Integer)
IEmin Mininum part or subset internal energy.
Default = 0 (Real)
[ J ]
IEmax Maximum part or subset internal energy.
Default = 1E+30 (Real)
[ J ]
KEmin Minimum part or subset kinetic energy.
Default = 0 (Real)
[ J ]
KEmax Maximum part or subset kinetic energy.
[ J ]
Tmin Minimum time duration before activation when criteria is reached. 5
(Real)
[ s ]
IEtol Tolerance for constant internal energy definition.
Default = 0.05 (Real)
IEtime Minimum time duration for activation when constant internal energy is reached.
[ s ]
KEtol Tolerance for constant kinetic energy definition.
KEtime Minimum time duration for activation when constant kinetic energy is reached.
[ s ]
  1. Sensors can be used to activate airbags, imposed forces, pressures, and fixed velocities.
  2. Sensors can be used to activate or deactivate these elements with /ACTIV.
  3. Sensors can be used to generate animations or h3d frames at specific conditions with the Engine keywords /ANIM/LSENSOR or /H3D/LSENSOR.
  4. Sensors can be used to terminate a simulation at specific conditions with the Engine keyword /STOP/LSENSOR.
  5. For sensor type ENERGY.
    The sensor is activated when the internal or kinetic energies satisfy the criteria for the defined part or subset.
    • Internal energy < IEmin or Internal energy > IEmax during time > Tmin
    • Kinetic energy < KEmin or Kinetic energy > KEmax during time > Tmin
    • Internal energy is constant during IEtime with tolerance IEtol
    • Kinetic energy is constant during KEtime with tolerance KEtol
  6. IEtol is defined as standard deviation divided by mean value, both based on exponential average over time interval IEtime.
  7. KEtol is defined as standard deviation divided by mean value, both based on exponential average over time interval KEtime.
