/SENSOR/NOT
Block Format Keyword Describes the sensors used to activate or deactivate an object according to Boolean NOT of another sensor.
/SENSOR/NOT/sens_ID/unit_ID
sens_title
Tdelay
sens_ID1
Definition
sens_ID Sensor identifier.
(Integer, maximum 10 digits)
unit_ID Optional unit identifier.
sens_title Sensor title.
Tdelay Time delay.
(Real)
[ s ]
sens_ID1 Activation sensor identifier IS1.
(Integer)
  1. Sensors can be used to activate airbags, imposed forces, pressures, and fixed velocities.
  2. Sensors can be used to activate or deactivate these elements: brick, quad, shell, truss, beam, spring or 3N Shell with /ACTIV.
  3. For Sensor type NOT:
    The sensor is activated one cycle after deactivation of sens_ID1.
    clip0132
