/SENSOR/DIST_SURF
Block Format Keyword Describes the sensors used to activate or deactivate an object according to the shortest distance from a reference node to a plane or a surface.
/SENSOR/DIST_SURF/sens_ID/unit_ID
sens_title
Tdelay
node_ID Node_1 Node_2 Node_3
Dmin Dmax Tmin
Definition
sens_ID Sensor identifier.
(Integer, maximum 10 digits)
unit_ID Optional unit identifier.
sens_title Sensor title.
node_ID Reference node identifier.
(Integer)
Node_1 First node for the plane surface definition.
(Integer)
Node_2 Second node for the plane surface definition.
(Integer)
Node_3 Third node for the plane surface definition.
(Integer)
Dmin Distance minimum.
Default = -1E30 (Real)
[ m ]
Dmax Distance maximum.
Default = 1E30 (Real)
[ m ]
Tmin Minimum time duration before activation when criteria is reached. 3
(Real)
[ s ]
  1. Sensors can be used to activate airbags, imposed forces, pressures, and fixed velocities.
  2. Sensors can be used to activate or deactivate these elements: brick, quad, shell, truss, beam, spring or 3N Shell with /ACTIV.
  3. For Sensor type DIST_SURF, the sensor is activated when distance D < D min MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGebGaey ipaWJaamiramaaBaaaleaaciGGTbGaaiyAaiaac6gaaeqaaaaa@3CFC@ or D > D max MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGebGaey Opa4JaamiramaaBaaaleaaciGGTbGaaiyyaiaacIhaaeqaaaaa@3D02@ during Tmin value.
