/SENSOR
Block Format Keyword Describes the sensors which are used to activate or deactivated an object according to the defined characteristics.
Sensor Type
- Type
- Description
- TYPE0, TIME
- Start time
- TYPE1, ACCE
- Accelerometer
- TYPE2, DIST
- Nodal distance
- TYPE3, SENS
- Activation with sens_ID1
- TYPE4, AND
- ON when sensors sens_ID1 AND sens_ID1 are ON
- TYPE5, OR
- ON when sensors sens_ID1 OR sens_ID2 are ON
- TYPE6, INTER
- Activation/Deactivation of sensor by interface contact
- TYPE7, RWALL
- Activation/Deactivation of sensor by contact with rigid wall
- TYPE8, NOT
- ON when sens_ID1 is OFF
- TYPE10, GAUGE
- Pressure gauge
- TYPE11, RBODY
- Activation of sensor by Rigid Body force criteria
- TYPE12, SECT
- Activation of sensor by Section force criteria
- TYPE13, WORK
- Activation of sensor by Work criteria
- TYPE14, ENERGY
- Activation of sensor by part or subset internal or kinetic energy criteria
- TYPE15, DIST_SURF
- Shortest distance from a reference node to a plane or a surface
- TYPE16, HIC
- Head Injury Criteria (HIC)
- USER1, USER2, USER3
- User's sensor
- The sensor types AND, OR, NOT, INTER, RWALL, RBODY and SECT work with all options using sensors.
- USER1,
USER2 and USER3 are sensors that you may
create.
The input format must be defined by a user supplied program. Refer to the Radioss User Subroutine Manual for more information about programming user sensors.
