/ACTIV
Block Format Keyword Describes the deactivation/activation of element groups.
/ACTIV/activ_ID/unit_ID
activ_title
sens_ID grbric_ID grquad_ID grshel_ID grtrus_ID grbeam_ID grspr_ID grsh3n_ID   Iform
Insert if Iform=2
Tstart Tstop
activ_ID Element deactivation block identifier.
(Integer, maximum 10 digits)
unit_ID (Optional) Unit Identifier
activ_title Element deactivation block title.
(Character maximum 100 characters)
sens_ID Sensor identifier.
(Integer)
grbric_ID Brick element group identifier.
(Integer)
grquad_ID Quad element group identifier.
(Integer)
grshel_ID Shell element group identifier.
(Integer)
grtrus_ID Truss element group identifier.
(Integer)
grbeam_ID Beam element group identifier.
(Integer)
grspr_ID Spring element group identifier.
(Integer)
grsh3n_ID 3N shell element group identifier.
(Integer)
Iform Formulation flag.
=1 (Default)
Elements are deactivated when the sensor is activated (ON).
=2
Elements are activated when T > T s t a r t or if sens_ID is defined T > T s t a r t + T s e n s o r .
Elements are deactivated when T > T s t o p MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamivaiabg6 da+iaadsfadaWgaaWcbaGaam4CaiaadshacaWGVbGaamiCaaqabaaa aa@3CB7@ or if sens_ID is defined T > T s t o p + T s e n s o r MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamivaiabg6 da+iaadsfadaWgaaWcbaGaam4CaiaadshacaWGVbGaamiCaaqabaGc cqGHRaWkcaWGubWaaSbaaSqaaiaadohacaWGLbGaamOBaiaadohaca WGVbGaamOCaaqabaaaaa@4460@ .
(Integer)
Tstart Activation time for Iform=2.
(Real)
[ s ]
Tstop Deactivation time for Iform=2.
Default = 1.0E+30 (Real)
[ s ]
  1. Iform= 1: all elements belonging to specified groups are deactivated when the sensor is activated (ON). These elements are not deleted.
    They may be reactivated when the sensor is deactivated - see /SENSOR criteria.
    Iform=2:
    All elements belonging to specified groups are activated when:
    • T > T s t a r t
    • or T > T s t a r t + T s e n s o r if a sensor is given
    ll elements belonging to specified groups are deactivated when:
    • T > T s t o p
    • or T > T s t o p + T s e n s o r if a sensor is given
    Where, T s e n s o r is the sensor activation time.
  2. Deactivated elements must not belong to any rigid bodies.
