/SENSOR/TIME
Block Format Keyword Describes the sensors used to activate or deactivate an object according to time delay.
/SENSOR/TIME/sens_ID/unit_ID
sens_title
Tdelay
Definition
sens_ID Sensor identifier.
(Integer, maximum 10 digits)
unit_ID Optional unit identifier.
sens_title Sensor title.
Tdelay Time delay.
(Real)
[ s ]
  1. Sensors can be used to activate airbags, imposed forces, pressures, and fixed velocities.
  2. Sensors can be used to activate or deactivate these elements: brick, quad, shell, truss, beam, spring or 3N Shell with /ACTIV.
  3. For Sensor type TIME, the sensor is activated after the time delay Tdelay. Tdelay is not applicable with the force based sensors type RWALL, INTER, RBODY, WORK or SECT.
