/SENSOR/DIST
Block Format Keyword Describes the sensors used to activate or deactivate an object according to distance.
/SENSOR/DIST/sens_ID/unit_ID
sens_title
Tdelay
node_ID1 node_ID2 Dmin Dmax
Definition
sens_ID Sensor identifier.
(Integer, maximum 10 digits)
unit_ID Optional unit identifier.
sens_title Sensor title.
Tdelay Time delay.
(Real)
[ s ]
node_ID1 Node identifier 1.
(Integer)
node_ID2 Node identifier 2.
(Integer)
Dmin Distance minimum.
Default = -1E30 (Real)
[ m ]
Dmax Distance maximum.
Default = 1E30 (Real)
[ m ]
  1. Sensors can be used to activate airbags, imposed forces, pressures, and fixed velocities.
  2. Sensors can be used to activate or deactivate these elements: brick, quad, shell, truss, beam, spring or 3N Shell with /ACTIV.
  3. For Sensor type DIST:
    • Nodal distance node_ID node_ID2 is defined as:
      Dmin < | node_ID node_ID2 | < Dmax
    • If Dmax is reached in traction (| node_ID node_ID2 | > Dmax) or Dmin is reached in compression (| node_ID node_ID2 | < Dmin) at time Tsensor, the sensor is then activated at time Tsensor:
      Tsensor = Tdelay + TR
