/STACK
Block Format Keyword Used to define the stacking sequence of a composite shell (/PROP/PCOMPP) in conjunction with the /STACK option.
- All elements may have different number of plies by associating a group of elements to the ply in a way similar to OptiStruct.
- The layout is described by a sequence of substacks ("SUB"), which are comprised of several plies. The interface between substacks is defined with INT option line.
The input can be either "substack" or by ply, but not both.
/STACK/stack_ID/unit_ID | |||||||||
stack_title | |||||||||
Ishell | Ismstr | Ish3n | Idril | Z0 | |||||
hm | hf | hr | dm | dn | |||||
Ashear | Iint | Ithick | |||||||
VX | VY | VZ | skew_ID | Iorth | Ipos | IP |
Pply_IDi | Zi | ||||||||
Blank |
Sub | Nsub | Sub-plyn | |||||||
Substack Name | |||||||||
Blank | |||||||||
Pply_IDj | Zj | ||||||||
Blank |
INT | Pply_IDt | Pply_IDb |
stack_ID | Stack
identifier. (Integer, maximum 10 digits) |
unit_ID | Unit Identifier. (Integer, maximum 10 digits) |
stack_title | Stack title. (Character, maximum 100 characters) |
Ishell | Shell element formulation
flag. 2
(Integer) |
Ismstr | Shell small strain
formulation flag. 3
(Integer) |
Ish3n | 3 node shell element
formulation flag.
(Integer) |
Idril | Drilling degree of freedom
stiffness flag. 7
(Integer) |
Z0 | Distance from the shell
element reference plane to the bottom surface of the shell (Real or
blank). It should be considered, if Ipos =2. Default = 0.0 (Real) |
hr | Shell membrane hourglass
coefficient. 4 Default = 0.01 (Real) |
hf | Shell out-of-plane
hourglass. Default = 0.01 (Real) |
hr | Shell rotation hourglass
coefficient. Default = 0.01 (Real) |
dm | Shell membrane
damping. For additional information, refer to Hourglass Resistance in the Theory Manual.
(Real) |
dn | Shell numerical damping.
5 It only used for Ishell =12 and 24
(Real) |
Ashear | Shear factor. Default is Reissner value: 5/6 (Real) |
Iint | Thickness integration
formulation - through ply thickness. 1
(Integer) |
Ithick | Shell resultant stresses
calculation flag.
(Integer) |
VX | X component for reference
vector. 8 Default = 1.0 (Real) |
VY | Y component for reference
vector. Default = 0.0 (Real) |
VZ | Z component for reference
skew_ID | Skew identifier for
reference vector. 8 Default = 0 (Integer) |
Iorth | Orthotropic system
formulation flag for reference vector.
(Integer) |
Ipos | Ply positioning flag for
reference vector. 9
(Integer) |
IP | Reference direction in
shell plane. 8
(Integer) |
Pply_IDi | Ply identifier for ply
i. (Integer) i =1, 2, 3 ...N |
Angle for ply
i. 8 (Real) |
Zi, | Z position of ply
i
(Zi or
defines the position of the middle of the ply). Default = 0.0 (Real) |
Sub | =SUB: Indicates the
beginning of a substack definition (must be left justified). 10 (Integer) |
Nsub | Substack identification
number. (Integer) |
Sub-plyn | Number of plies in
substack. (Integer) |
Substack Name | Name of the
substack. (Maximum 100 characters) |
INT | Indicates the connection between 2 substacks (must be left
justified). (Integer) |
Pply_IDt | Ply
identification number of the top ply of the bottom substack. One
of ply ID in
Pply_IDi or
Pply_IDj. (Integer) |
Pply_IDb | Ply
identification number of the bottom ply of the top substack. One of ply ID in
Pply_IDi
or
Example (Substack with /DRAPE)
/UNIT/1
unit for mat
Mg mm s
/PROP/PCOMPP/1/1
PCOMPP example
/STACK/1/1
NEW_PROP_1
# Ishell Ismstr Ish3n Idril Z0
12 0 0 0 0
# hm hf hr dm dn
0 0 0 0 0
# Istrain Ashear Iint Ithick
0 0 1 0
# VX VY VZ skew_ID Iorth Ipos Ip
0 1 0 0 0 0 0
# Sub Nsub Sub-plyn
SUB 1 4
# Substack Name
TOP
# Pply_IDi PHIi Zi
11 45 0
# Pply_IDi PHIi Zi
12 -45 0
# Pply_IDi PHIi Zi
13 90 0
# Pply_IDi PHIi Zi
14 90 0
# Sub Nsub Sub-plyn
SUB 2 4
# Substack Name
LEFT
# Pply_IDi PHIi Zi
21 45 0
# Pply_IDi PHIi Zi
22 -45 0
# Pply_IDi PHIi Zi
23 90 0
# Pply_IDi PHIi Zi
24 90 0
# Sub Nsub Sub-plyn
SUB 3 4
# Substack Name
RIGHT
# Pply_IDi PHIi Zi
31 45 0
# Pply_IDi PHIi Zi
32 -45 0
# Pply_IDi PHIi Zi
33 90 0
# Pply_IDi PHIi Zi
34 90 0
# Sub Nsub Sub-plyn
SUB 4 3
# Substack Name
MIDDLE
# Pply_IDi PHIi Zi
41 45 0
# Pply_IDi PHIi Zi
42 -45 0
# Pply_IDi PHIi Zi
43 90 0
# Int Pply_IDt Pply_IDb
INT 14 21
INT 14 31
INT 43 21
INT 34 41
/PLY/11/1
Part number 11
# mat_ID_i t delta_phi grsh4n_I grsh3n_I Npt_ply A_i
4 .5 45 45 0 0 0
# drape_ID def_orth
1 2
/PLY/12/1
Part number 12
4 .5 45 45 0 0 0
# drape_ID def_orth
1 2
/PLY/13/1
Part number 13
4 .5 45 45 0 0 0
# drape_ID def_orth
1 2
/PLY/14/1
Part number 14
4 .5 45 45 0 0 0
# drape_ID def_orth
1 2
/PLY/21/1
Part number 21
4 .5 45 46 0 0 0
# drape_ID def_orth
0 0
/PLY/22/1
Part number 22
4 .5 45 46 0 0 0
# drape_ID def_orth
1 2
/PLY/23/1
Part number 23
4 .5 45 46 0 0 0
# drape_ID def_orth
1 2
/PLY/24/1
Part number 24
4 .5 45 46 0 0 0
# drape_ID def_orth
1 2
/PLY/31/1
Part number 31
4 .5 45 47 0 0 0
# drape_ID def_orth
1 2
/PLY/32/1
Part number 32
4 .5 45 47 0 0 0
# drape_ID def_orth
1 2
/PLY/33/1
Part number 33
4 .5 45 47 0 0 0
# drape_ID def_orth
1 2
/PLY/34/1
Part number 34
4 .5 45 47 0 0 0
# drape_ID def_orth
1 2
/PLY/41/1
Part number 41
4 .5 45 44 0 0 0
# drape_ID def_orth
2 2
/PLY/42/1
Part number 42
4 .5 45 44 0 0 0
# drape_ID def_orth
2 2
/PLY/43/1
Part number 43
4 .5 45 44 0 0 0
# drape_ID def_orth
2 2
/DRAPE/1
drape in shell group 1
# Entity Entity_ID Thinning Theta_drape
SHELL 2 45.
SHELL 3 45.
/DRAPE/2
drape in shell group 2
SHELL 1 -45.
/SHELL/3
1 43131 43138 43137 43132 0
2 43132 43133 43136 43137 0
3 43134 43132 43137 43135 0
#ENDDATA
- The stack is used in combination
with /PLY to create composites properties through the
ply-based definition. It is NOT compatible with /PROP/TYPE19 (PLY) option.
- Each ply in the stack is defined using Pply_IDi or Pply_IDj and can only be referenced once in the stack. If ply ids are used more than once an error message will output.
- Each ply of a shell element can contain a different (≥ 1) number of integration points through its ply thickness. That is, Npt_ply =3 in /PLY.
- Different integration scheme (uniformly distribution or Gauss integration scheme) could be defined with option Iint inside this property,
- Ishell, Ish3n – 4-node and 3-node shell formulation
flag.
- Ishell =1,2,3,4 (Q4): original 4 nodes Radioss shell with hourglass perturbation stabilization.
- Ishell =24 (QEPH): formulation with hourglass physical stabilization for general use.
- Ishell =12 (QBAT): modified BATOZ Q4γ24 shell with four Gauss integration points and reduced integration for in-plane shear. No hourglass control is needed for this shell.
- Ish3n =30 (DKT18): BATOZ DKT18 thin shell with three Hammer integration points.
- The hourglass formulation is visco-elastic for Q4 shells.
- Ismstr - Small strain formulation
- Small strain formulation is activated from time t = 0, if Ismstr=1. It may be used for a faster preliminary analysis, but the accuracy of results is not ensured. Any shell for which can be switched to a small strain formulation by Radioss Engine option /DT/SHELL/CST.
- If Ismstr=1, the strains and stresses which are given in material laws are engineering strains and stresses; otherwise they are true strains and stresses.
- hm, hf, and hr - hourglass coefficients
- hm, hf, and hr are only used for Q4 shells. They must have a value between 0 and 0.05.
- For Ishell = 3, default values for hm and hr are 0.1.
- dn - Shell
numerical damping It is only used for Ishell =12 or 24:
- for Ishell =24, dn is used for hourglass stress calculation
- for QBAT, dn is used for all stress terms, except transverse shear
- for DKT18, dn is only used for membrane
- Ithick - Shell resultant stresses calculation
flag.
- If Ithick= 1, the small strain option is automatically deactivated in the corresponding type of element
- Idril - Drilling degree of freedom stiffness
- Drilling DOF stiffness is recommended for implicit solutions especially for Riks method and bending dominated problems
- Idril is available for QEPH, QBAT (Ishell =12, 24), and standard triangle (C0) shell elements (Ish3n = 1, 2).
- Anisotropy direction
definition.The reference vector is defined as following according flag IP:
- If IP=0 and skew_ID = 0, the reference vector is defined with VX, VY and VZ.
- If IP=0 and skew_ID ≠ 0, the reference vector is the first direction (local X) of the local coordinate system skew_ID.
- If IP = 20, the reference vector is defined with the node N1 and N2 of the shell elements.
- If IP = 22, the reference vector is the first direction (local X) of the local coordinate system skew_ID. Vector components VX, VY and VZ are ignored.
- If IP = 23, the reference vector is defined with VX, VY and VZ. Local coordinate system skew_ID is ignored.
The reference vector is projected on the shell element plane and becomes the vector . Then for each layer, the 1st material direction (m1) is vector turned degrees (turns positive direction around shell normal ).The hierarchy order to define the reference vector is:- shell element ( > 0 in either /SHELL or /SH3N)
- initial state card (/INISHE/ORTHO)
- shell property
In case of reference metrics, the orientation for directions of anisotropy must be defined with the reference geometry, not the initial one. The 2nd material direction m2 is derived from direction m1 with the angle (defined in /PLY). If , the layer is orthotropic.
- Ipos - ply position
- In this property, ply position defined with and option Ipos.
- values are real ply positions in the local Z axis (negative and positive value are allowed and defines the position of the middle of the each ply).
- only used with Ipos=2, it indicated distance from the shell element reference middle surface to the bottom surface of the whole ply or stack. For additional information, see Ipos=2
- Ipos = 0: ply positions are
automatically calculated with regard to ply thicknesses.
- The input thickness “Thick” may be equal to zero as the true shell thickness is always calculated from the ply thicknesses and positions of ply defined by .
- If the input thickness “Thick” is different from 0.0, a warning will be displayed if the calculated thickness from the plies is different from the input thickness.
- Ipos = 1: All ply positions and
thickness in the element are user-defined (with in
/PLY and
- Global thickness “Thick” is not checked, as it does not need to be equal to the sum of ply thickness
- Multiple plies are allowed to have the same space position
- This option is not recommended unless the number of ply is constant for all elements
- Ipos = 2: the shell element mid-surface is at from the bottom of the ply layout.
- Ipos = 3: the top of the ply layout is coincident with the element mid-surface.
- Ipos = 4: the bottom of the ply layout is coincident with the element mid-surface.
- Define by substack.
- If the substack definition is used, each substack definition begins with the keyword "SUB" and the substack identification number.
- All the plies until the next keyword "SUB" or the keyword "INT" is encountered belong to the same substack.
- All substacks must be defined before defining the “INT connections
- If an element contains plies belonging to several substacks, the connection between the substacks is defined with an “INT” connection: the ply Pply_IDt of the first substack is connected to the ply Pply_IDb of the second substack.
- For additioinal inforation, refer to the above examples for this property.
- Material for each ply.
- Material for each ply defined with mat_ID in /PLY.
- Different material laws could be defined for each ply.
- The material law number given in /PART will be used to define the mass and the sound speed of the composite, as well as the interface stiffness.
