/MAT/LAW200 (MDS)
Block Format Keyword This law is a link to Multiscale Designer material law.
This material is not compatible with failure models, viscous model or thermal options. All damage and failure are defined inside of the material directly. This material is compatible with shell and any solid elements.
/MAT/LAW200/mat_ID/unit_ID or /MAT/MDS/mat_ID/unit_ID | |||||||||
mat_title | |||||||||
mds_material_file | |||||||||
FLAG | |||||||||
fiber_orientation_file | |||||||||
Fail_1 | Fail_1_l | Fail_1_u | Fail_2 | Fail_2_l | Fail_2_u | ||||
Ifail |
mat_ID | Material
identifier. (Integer, maximum 10 digits) |
unit_ID | Unit Identifier. (Integer, maximum 10 digits) |
mat_title | Material
title. (Character, maximum 100 characters) |
mds_material_file | mdsMAT material file
name. (Character, maximum 100 characters) |
FLAG | Material option.
fiber_orientation_file | The
_mdsFiberOri.dat filename. Used only if
FLAG=FIBER. (Character, maximum 100 characters) |
Fail_1 | 1st MDS Failure
model identifier. (Integer) |
Fail_1_l | Lower limit for the 1st Failure
criteria. (Real) |
Fail_1_u | Upper limit for the 1st Failure
criteria. (Real) |
Fail_2 | 2nd MDS Failure model
Fail_2_l | Lower limit for the 2nd Failure
criteria. (Real) |
Fail_2_u | Upper limit for the 2nd Failure
criteria. (Real) |
Ifail | Failure flag
(Integer) |
Example (MDS)
#RADIOSS STARTER
/MAT/MDS/1
# title
material MDS
# Material File name
material1_mdsMAT.dat
# Material Option
FIBER
# Fiber orientation file name
mdsFiberOri.dat
# Fail_1 Fail_1_l Fail_1_u Fail_2 Fail_2_l Fail_2_u
0 0.0 0.0 0 0.0 0.0
# Ifail
0
/MAT/MDS/2
# title
material MDS
# Material Option
0 0.0 0.0 0 0.0 0.0
# Ifail
0
#ENDDATA
/END
- This material law is a direct input to Radioss for the Multiscale Designer material law. Information about the contents of the different files are available in Multiscale Designer Reference Guide.
- /MAT/LAW200 (MDS) is available to interface Radioss with Multiscale Designer to include a much wider range of different material models.
- Multiscale Designer is an efficient tool for development and simulation of multiscale material models of continuous, woven, and/or chopped fiber composites, honeycomb cores, reinforced concrete, soil, bones, and various other heterogeneous materials.
- Applications include multiscale
material modeling for design, ultimate failure, statistical- based material
allowables, fatigue, fracture, impact, crash, environmental degradation, and
multiphysics simulations.
- Develop multiscale material models using forward homogenization and inverse optimization technologies.
- Built-in parametric unit cells for unidirectional, woven, chopped, and particulate fiber composites.
- Simulate nonlinear material behavior including ultimate failure at the micro-scale.
- Obtain virtual material allowables supported by test and perform fatigue analysis.
- Efficient plug-ins to commercial FEA codes OptiStruct and Radioss.
- If the /MAT/LAW200 (MDS) entry is specified, then Radioss looks for the Multiscale Designer installation within the same Mechanical Solvers installation from which the Radioss run is initiated. The MDSDIR I/O Options Entry can also be used to specify the Multiscale Designer installation location, if it has been installed in a different location.
