Engine Keyword Generates animation files containing vectorial data for
the specified variable.
/ANIM/VECT/Restype/Keyword4
Field |
Contents |
SI Unit Example |
Restype |
Variable name to be
saved in animation file:
- VEL
- Velocities
- DISP
- Displacements
- ACC
- Accelerations
- CONT
- Contact forces
- CONT/MAX
- Maximum contact forces over time
- CONT2
- Tied interface forces
- FINT
- Internal forces
- FEXT
- External forces
- FOPT
- Forces and moments for rigid bodies, rigid walls and
sections.
- PCONT
- Contact pressure animation vector.
- PCONT2
- Tied contact pressure animation vector.
- VROT
- Rotational velocities
- Idrot=1 must also be
set in /IOFLAG; otherwise, rotational
degree of freedom (DOF) are not computed and this option
is ignored.
- DROT
- Rotations
DOF are not computed and this option is ignored.
- FVEL
- Gas velocity vectors for fluid flow in Finite Volume
Method monitored volume type /FVMBAG1
(or /FVMBAG) keywords. 2
- FREAC
- Reaction forces for imposed velocities, displacements,
accelerations and boundary conditions.
- MREAC
- Reaction moments for imposed velocities, displacements,
- CLUST/FORCE
- Spot weld /CLUSTER force vector in
global coordinates.
- CLUST/MOM
- Spot weld /CLUSTER moment vector in
global coordinates.
- If Restype
=PCONT (for contact interfaces) and
Restype =PCONT2 (for tied contact),
two nodal vectors are output:(1)
Where,
- Sum of normal contact forces applied to the node
- Sum of tangential contact forces applied to the node
- Extrapolated surface of segments connected to the node
- The nodal fluid velocity values
displayed on internal surfaces are computed from the values of the Finite Volumes
located on the opposite to the shell normal side.
