/IOFLAG
Block Format Keyword Describes the input-output flags.
/IOFLAG | |||||||||
Ipri | Ioutp | OutyyFmT | Irootyy | Idrot |
Ipri | Starter output printout flag.
(Integer) |
Ioutp | Output a STY model file flag.
(Integer) |
OutyyFMT | STY file output format flag.
(Integer) |
Irootyy | STY file name flag.
(Integer) |
Idrot | Force computation of
rotational DOF flag.
(Integer) |
- run#: Radioss run number (four digits) from 0000 to 9999.
- OutyyFmT = 2 is only working if all IDs (node, element, ...) are using less than 9 digits.
- Only Binary 64-bit restart file can be used.
