RD-SL-T: 1040 Drop Test - Quick Setup Workflow
This tutorial demonstrates a drop test using the Quick Setup panel.
- Create a drop test solution using the Quick Setup panel
Prerequisites
To run this simulation, you will need access to a licensed version of SimLab and Radioss. You will need an internet connection to watch the video tutorials and download the files.
Model Files
Tutorial Video
Additional Resources
For more tutorials, visit the SimLab Learning Center.
